Author Topic: JRW'S 91 318is turbo build  (Read 93949 times)
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #135 on: December 04, 2014, 06:46:04 PM »
Probably to weld in a cage??
-Nick
91 E30 M42 with VEMS
jrw21
  • -Receive: 6
« Reply #136 on: December 04, 2014, 08:12:39 PM »
I forgot to mention the plans on the roof. The old sunroof was a total loss as well as the cause of lots of the rust issues the chasis had. So I junked it and will be riveting on a sheet of aluminum with sealant then filler to blend. This will save a massive amount of top weight too!
jrw21
  • -Receive: 6
« Reply #137 on: December 07, 2014, 07:17:45 PM »
Chasis, trunk and engine compartment sprayed with 2k epoxy with ceramic resin. Stuff is rock solid and super thick.
keflaman
  • -Receive: 35
« Reply #138 on: December 08, 2014, 05:12:37 AM »
The body work is very impressive!
jrw21
  • -Receive: 6
« Reply #139 on: December 08, 2014, 08:25:08 PM »
Thanks! Not going to lie though..starting to get a bit anxious to start wrenching again. 8) Knowing my luck I will chip the coating banging tools/parts against it! Going to wait a few days for the epoxy coating to get a good cure before I start bolting the suspension back on. So, in the meantime I need to take inventory of what I have and don't have so I don't get any surprises later!
Here is a teaser of the Suspension/subframe back from Powdercoating:
jrw21
  • -Receive: 6
« Reply #140 on: December 20, 2014, 08:06:49 PM »
Got a bit of work done tonight on the suspension. Poly mounts from revshift all around and front Ireland Engineering poly for the sway bar.
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #141 on: December 20, 2014, 09:21:51 PM »
Dang, thats clean!
The Eastwood 2k primer is supposed to be quite good too.
-Nick
boosted3k
  • Boost over everything
« Reply #142 on: December 22, 2014, 03:28:40 PM »
subbed
Are You Not Entertained? Are You Not Entertained?
1994 3000gt Vr4
1991 BMW 318is
jrw21
  • -Receive: 6
« Reply #143 on: December 28, 2014, 03:38:49 PM »
Suspension is finally on! Dang its been a long time since this car actually sat on wheels! Next on the list is clean up the brakes, prep the z3 steering rack, then choose a diff. Not 100% sure on diff ratio yet. I have 2.93 medium case and a 3.64 small case. Not sure I want to use either of them. The zf 310z I will be using behind the m42 has a 1:1 final drive. So with that in mind I may look for a 3.25 LSD.
Tgoode318
  • -Receive: 11
« Reply #144 on: December 28, 2014, 06:19:39 PM »
Nice, i have heard good things about IE Polly, its supposed to be a great street/autocross set up. As for your diff a 3.25 lsd might be in your future.
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
jrw21
  • -Receive: 6
« Reply #145 on: December 29, 2014, 05:59:06 PM »
Nick what diff ratio do you have behind your zf? If I recall its pretty short like 3.73 or is it a 4.10?
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #146 on: December 29, 2014, 10:40:38 PM »
Yes, I am running a 3.73 which is really short. Its great for an atmospheric car, but it will be way too steep for a turbo car.
Here is a little chart I made to help determine what rear ratios will work best for different situations:
As mentioned above, a 3.25 would probably do pretty good in a turbo car.
« Last Edit: December 29, 2014, 10:43:13 PM by wazzu70 »
-Nick
jrw21
  • -Receive: 6
« Reply #147 on: December 30, 2014, 05:14:44 PM »
Nice chart. I was running my numbers based on an old diffsonline spreadsheetand your numbers are spot on with what I am getting with the spreadsheet.
I run a lot down the interstate as I live a mile off one. So, I don't want anything too steep but want to retain some good torque for strip/track. The 3.25LSD looks to be the best of both worlds. 3.46lsd is VERY tempting puts me at ~3600rpm @ 75mph.
« Last Edit: December 30, 2014, 05:33:43 PM by jrw21 »
jrw21
  • -Receive: 6
« Reply #148 on: January 04, 2015, 07:00:00 PM »
Well, I decided on and purchased a 3.46 LSD. Price was right so that helped make the decision easier.
Just finished a complete rebuild on 4 brakes. OEM rebuild kits and Hawk HPS pads.
« Last Edit: January 04, 2015, 07:01:37 PM by jrw21 »
colin86325
  • -Receive: 15
« Reply #149 on: January 06, 2015, 09:54:44 AM »
Did you paint your rotors?
