Author Topic: JRW'S 91 318is turbo build  (Read 93760 times)
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #225 on: July 28, 2018, 12:07:50 PM »
.83A/R T4 twinscroll housing. Did you make a new manifold or just adapt to a T4 flange and keep it open collector?
Which compressor did you go with? 56mm or 51mm?
Curious because I have been dreaming of a similar setup on my car. Also curious how it compared to the ford T3 60trim. Ive been concerned the S200sx is too large of a turbine.
The N55 turbocharger is essentially an S100 turbine with an EFR 62mm wheel ans smaller inducer. I think that would be an awesome turbo!
-Nick
91 E30 M42 with VEMS
jrw21
  • -Receive: 6
« Reply #226 on: July 30, 2018, 01:25:30 PM »
This is the 51mm version. For now it is bolted on with an adapter. May make a new manifold for it at some point.
Going to run it on the dyno tomorrow, will post results.
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #227 on: August 01, 2018, 09:49:28 AM »
Awesome, that seems like it will be a good fit. The 56mm would probably be too big and be sluggish.
-Nick
jrw21
  • -Receive: 6
« Reply #228 on: August 06, 2018, 08:08:06 PM »
Today, 330whp/281two @ 25psi
Last run tomorrow shooting for 30psi!
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #229 on: August 09, 2018, 12:02:35 PM »
Awesome! How is the transient response in comparison to the T3?
-Nick
jrw21
  • -Receive: 6
« Reply #230 on: August 13, 2018, 08:16:43 PM »
here are the charts:
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #231 on: August 15, 2018, 08:58:03 AM »
Great results! It must really scoot :)
Do you feel the drivability is not as good with the bigger turbo? Very curious if its too much sacrifice!
-Nick
jrw21
  • -Receive: 6
« Reply #232 on: August 15, 2018, 04:54:21 PM »
Not sure on the street. The chassis still needs buttoned back up. Debating right now how to proceed. 80lb injectors are at 85-90% duty cycle at 340whp/26psi and wastegate springs won't hold pass 26psi. So, honestly I am tempted to upgrade the injectors and spring and see what it can do?
« Last Edit: August 15, 2018, 05:00:04 PM by jrw21 »
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #233 on: August 16, 2018, 03:15:56 PM »
Focus on getting it driving first. You may find there is somewhere better to put that money!
-Nick
jrw21
  • -Receive: 6
« Reply #234 on: August 16, 2018, 03:47:46 PM »
Well, this many years into this project its hard to settle... Honestly, it may please more to see it produce.  :o
