Author Topic: JRW'S 91 318is turbo build  (Read 93824 times)
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #195 on: January 29, 2016, 09:59:10 PM »
Interesting intake manifold. I have been searching out design options for an upgraded intake manifold for my Turbo M42, since I've heard from multiple people that it becomes a weak link in the flow path around 300bhp, I can't weld aluminum though, which is a problem.
There is no way the stock manifold is a weak link around 300hp on a turbo engine. Where would the restriction be?
There are advantages to making a short runner unit like JRW did though. It will give you better top end and of course the IC outlet routing is cleaner. The different throttle body is nice too.
-Nick
91 E30 M42 with VEMS
MoMansi
  • Bimmers are built not bought
« Reply #196 on: January 31, 2016, 02:20:05 AM »
the intake manifold is really interesting for N/A use, i love it, i guess the bigger air box will help more on the top end for the turbo, i'm no FI expert though...
Ex-320is owner, had 3 S14B20 engines, love the 4 cylinders more!
unban me please
« Reply #197 on: February 29, 2016, 07:06:15 PM »
This is JRW....Have a few updates but for whatever reason I was banned from the forum. So if a mod see's this please explain why I was banned.
« Reply #198 on: March 03, 2016, 12:19:11 AM »
Hey JRW, not sure what's going on, it looks like you should have full permissions. If you are still stuck let me know and I'll keep looking into it.
« Reply #199 on: March 03, 2016, 08:32:42 PM »
I think he's OK. I was testing a ban on Yahoo.com and forgot to remove it. It's fixed now.
Sorry for any trouble!
Darky
  • -Receive: 23
« Reply #200 on: March 11, 2016, 05:23:06 PM »
Hi
Any reason your using the standard brake master cylinder, actually less than standard that's a 318i type.
Cheers Rohan
jrw21
  • -Receive: 6
« Reply #201 on: March 18, 2016, 09:47:17 AM »
Hi
Cheers Rohan
Hey Rohan
That is actually a master cylinder from a 1974ish VW Rabbit. The bore size is perfect for booster-less setups.
jrw21
  • -Receive: 6
« Reply #202 on: March 18, 2016, 09:51:55 AM »
I'm back guys! Have a ton of updates but I will get to those later...But, here is a huge milestone!
First start!
http://vidmg.photobucket.com/albums/v83/whitebred21/20160315_181900_001_zpsgqkwdxlf.mp4
« Last Edit: March 18, 2016, 09:53:26 AM by jrw21 »
keflaman
  • -Receive: 35
« Reply #203 on: March 19, 2016, 06:22:41 AM »
What a neat and tidy install! Looks great, man!!
Darky
  • -Receive: 23
« Reply #204 on: March 19, 2016, 03:10:49 PM »
Nice work!
varg
  • Anomalous
  • Needs more boost!
« Reply #205 on: April 08, 2016, 03:03:48 PM »
The general design could hamper flow at the top end. As I stated, it's what I've heard from 2 separate people who have themselves done the whole 300whp thing before. I have no way of verifying it, short of building a custom manifold and doing back to back dyno runs I could not be sure, but given the design of the manifold, it seems reasonable. I have a turbo and a fuel system that's easily capable of it but I still don't have a TIG welder so we'll see if I'm able to break 300whp with a stock manifold, I will certainly post my findings if I do.
'91 318is, stock internals, T3/T04E 50 trim/.48ar, coilovers
project thread
Delta
« Reply #206 on: April 12, 2016, 04:51:38 PM »
Awesome build!
I'm really interested in that oil cooler cap. Looking into other style caps on the market none of them say anything about the m42. Ireland says that theirs doesn't work, so I'm intersted in how you got this one to work. Particularly, what oil filter element did you end up using? I plan to get a similar cap from Rally Road for their s52 fitment.
Im sure many others would be interested in this as well!
Darky
  • -Receive: 23
« Reply #207 on: April 13, 2016, 01:55:09 AM »
Be interesting to see what you do with regards to the oil filter cap. I know those filter caps fit, however from memory they couldn't find a filter to work either to tall or short. But perhaps a spacer might work!
Delta
« Reply #208 on: April 13, 2016, 11:06:02 AM »
I ended up sending an email out to the guys at Rally Road and asked them if their m50 oil cooler cap would work with our motors. They got back to me last night and said that they can have an o-ringed spacer machined for the bottom of the filter housing that allows the use of a newer cartridge filter. Definitely give those guys a shout!
I'm probably going to be getting the cap and spacer from them sometime later this year. Glad there is actually an easier/cheaper option than the mocal diverter plate!
Darky
  • -Receive: 23
« Reply #209 on: April 16, 2016, 09:57:46 PM »
Which gearbox did you end up using?
