Author Topic: E36 M42 tranny and E30 M42 tranny...  (Read 10831 times)
romkasponka
« Reply #15 on: January 14, 2009, 08:11:35 AM »
Quote from: Daniele30;64646
Do you have any issue with the prop shaft(long shaft) ?? direct fit by using
e36 front & rear long shaft ?
You can adjust propshaft lenght..
E30 318is M42
E36 318is M44
fabe
« Reply #16 on: January 14, 2009, 08:59:37 AM »
Quote from: romkasponka;64653
just to double confirm.. You mean adjust the existing E30 propshaft?? Cos daniel's question was on the E36 propshaft..
romkasponka
« Reply #17 on: January 14, 2009, 05:30:08 PM »
Quote from: fabe;64655
E36 propshaft is adjustable also...
E30 318is M42
E36 318is M44
fabe
« Reply #18 on: January 15, 2009, 01:11:41 AM »
I understand that they are adjustable...
So you used back the E30 propshaft with the E36 gearbox??
romkasponka
« Reply #19 on: January 15, 2009, 02:19:58 AM »
Quote from: fabe;64709
I used all, NOT ONLY BACK, E30 driveshaft with E36 gearbox in E30  :)
E30 318is M42
E36 318is M44
fabe
« Reply #20 on: January 15, 2009, 03:00:07 AM »
Quote from: romkasponka;64712
Thanks... That was the confirmation I was looking for...
romkasponka
« Reply #21 on: January 15, 2009, 03:24:13 AM »
Quote from: fabe;64713
you are welcome...
E30 318is M42
E36 318is M44
Daniele30
« Reply #22 on: January 15, 2009, 07:27:56 AM »
Quote from: romkasponka;64717
you are welcome...
oh thank god...
I think i shouldn't have any problem installing e36 box onto my e30.
I need to buy the aluminium shifter balancer too
I'm gonna use 87' 240 manual long shaft. hopefuly it can be fit as well.
« Last Edit: January 15, 2009, 07:41:13 AM by Daniele30 »
fabe
« Reply #23 on: January 15, 2009, 08:45:14 AM »
romkasponka, actually I was trying to look for the thread on the transmission change.. Can't seem to locate it..
Want to know also about the lingkage rod. Are u using the one from the E30? Any modification required?
Daniele30
« Reply #24 on: January 15, 2009, 09:45:08 AM »
can i use this from e36 coupe ??
or have to use the e30 one ?
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #25 on: February 26, 2013, 12:58:44 PM »
Propshaft is the shaft from CSB to trans. I dont think this can be changed. I assume you are talking about the rear section that is splined?
I tried fitting the E30 driveline in the car with a G250 installed and the propshaft was too long. The CSB was too far behind the chassis mounting points.
Do people weld in new chassis attachment points for the CSB?
-Nick
91 E30 M42 with VEMS
romkasponka
« Reply #26 on: February 26, 2013, 01:46:50 PM »
In my case driveshaft was shortened through splines and was short enough to install E36 ZF 225 gearbox. In future I am planning to replace it with one peace driveshaft in order to move engine backwards and save some weight.
If you miss few millimeters you can elongate the holes.
E30 318is M42
E36 318is M44
