Author Topic: Hi there  (Read 95589 times)
ludiagsm
Hi there
« Reply #60 on: July 04, 2007, 01:42:09 PM »
Quote from: Alibi;29047
The rear halfshafts are from 325 too.
This car runs like hell .... the new Turbonetics is .... OH MY GOT :eek:
А Луд ти като си със скоростна от 325, пасва ли съединителя от ИС-ката? (Ludiagsm, does your Clutch from the IS fits with the 325 Gearbox).
:) it fits no problem ( kak si bate neznaeh 4e 4ete6 i tuka :) )
ludiagsm
Hi there
« Reply #61 on: July 04, 2007, 01:42:42 PM »
Quote from: nuvolarossa;29056
Ludiagsm, your wheels are 17" or 18"?:)
17'' borbet
ludiagsm
Hi there
« Reply #62 on: July 04, 2007, 01:50:30 PM »
today i made the wandering dino test  :)
on 2,3 bar of boost i have 380,3hp and467.2 Nm ot wheels that means that i have 437.345hp and  546.28 Nm on flywheel
thers is a pictures[/quote]
and two movies:to the  dino  http://youtube.com/watch?v=QUkZCiaWg3w
after the dino :) on Bulgarian>Sofya  streets http://youtube.com/watch?v=aSPs97fUt7A
nuvolarossa
Hi there
« Reply #63 on: July 04, 2007, 02:20:36 PM »
oh my god!!!! what numbers!!!!
I need to know ALL INTERNAL mods that you've done at that engine!!!
please...:o
« Last Edit: July 04, 2007, 04:03:44 PM by nuvolarossa »
Alpine003
Hi there
« Reply #64 on: July 04, 2007, 11:19:46 PM »
Very nice numbers indeed. I would still like to know your 60ft times and trap speed at the end of the 1/4 mile. You might not have these at your tracks since your metric over there. ;)
Do you run slicks at the tracks?
ludiagsm
Hi there
« Reply #65 on: July 05, 2007, 12:16:04 AM »
Quote from: Alpine003;29093
yes I use toyo street slick 235 45 17 , another nombers u dont know them for now but i will ask for them ,next time wen i go  on Bulgarian>Sofia town drag circuit
« Last Edit: July 05, 2007, 05:32:26 AM by ludiagsm »
nuvolarossa
Hi there
« Reply #66 on: July 05, 2007, 02:06:29 AM »
Quote from: nuvolarossa;29075
please...:o
So help me to make a list of mods of your engine:
- Wossner pistons from C20Let 87mm
- bored block to 87mm
- honda 138mm rods
the head is stock or is ported? Valves?
thanks:o
Alibi
Hi there
« Reply #67 on: July 05, 2007, 04:13:53 AM »
Wossner C20LET Pistons 86mm ;)
Honda Connection Rod
The Connection Rod Bearings are from 318tds or something like that (not sure)
Cometic Headgasket (He had it, but I don't know if he install it on the car)
So far I know, The Head is ported, but everything else is stock (as it came from the Munich) :D
He got an Oilcooler, Oilcatch tank (this is very important for high performance car).
Actually very interessting Mixture of Parts ... about the C20LET Pistons ... the stock cane make more then 350 hp. Those from Wossner are with sure stronger and with reduced weight. So I think, that he shouldn't have problems before 450-500 hp.
His Clutch is the same as mine :D ... so I know for sure, how strong it is.
Да е бате. Тука може да се научат доста интересни неща и то конкретно за нашите мотори. А й хората помагат с инфо от много места. Ти сложи ли Cometic гарнитурата? А и .. с какви болтове (шпилки) си? .. както и лагерите на биелите от ТДС ли са?
P.S. About the Wossner Pistons. I've contact them and they told me, that they can make a Custom Pistons for my car (so with the original size) with as big Compression Ratio as I told them. And it will cost me ... something like ... under 1000 Eu. The C20LET Pistons cost arount 600 eu (150 for 1) and the Custom one are something between 200-250 eu for 1. Those from MM are 800$ and they are also very strong and have 8.5:1 CR.
« Last Edit: July 05, 2007, 04:18:52 AM by Alibi »
nuvolarossa
Hi there
« Reply #68 on: July 05, 2007, 01:13:10 PM »
what camshaft (cams) has this monster of engine? stock or others?
ludiagsm
Hi there
« Reply #69 on: July 05, 2007, 06:11:01 PM »
Quote from: nuvolarossa;29132
from now on my cams are stock  i purchase a  256 to 256 degrees from shrik
and i will tell you how edngine works with them
nuvolarossa
Hi there
« Reply #70 on: July 09, 2007, 02:40:47 AM »
Ludiagsm, can you make this video:
-car in third gear, rolling at 1000-1500rpms, and then you floor it until the revlimiter?
I want to see how much turbo-lag it has at low rpms...
thanks:D
ludiagsm
Hi there
« Reply #71 on: July 11, 2007, 10:30:42 AM »
Quote from: nuvolarossa;29273
thanks:D
ok i 'll try this days ,but on the weekand I will make some tests with NOS system 150hp shot and if my engine survive after that :) i will post a video:)
Alpine003
Hi there
« Reply #72 on: July 11, 2007, 04:09:01 PM »
Quote from: ludiagsm;29423
You guys on the other side of the pond are crazy. First running 2 bar of boost and then 150 shot on top of that?
Is it a wet system?
ludiagsm
Hi there
« Reply #73 on: July 12, 2007, 03:13:33 PM »
Quote from: Alpine003;29451
Is it a wet system?
yes  with 4 nos nozzles http://img227.imageshack.us/my.php?image=smkolektorokok200220070qq0.jpg
« Last Edit: July 12, 2007, 03:17:37 PM by ludiagsm »
ludiagsm
Hi there
« Reply #74 on: July 15, 2007, 06:45:44 PM »
here they come :)
