Author Topic: BMW E36 Turbo M42 Build  (Read 15099 times)
RuthlessPerformance
    • Ruthless Performance Motorsports
« on: July 18, 2013, 10:34:26 PM »
Just wanted to share a Turbo M42 build I have been working on. Hope it meets with your approval. I have been using this site for much of my research, so I figured it was only right that I post it.  Here are some of the highlights:
Complete rebuild
H-Beam Rods
CP Turbo Pistons
VAC Stage 2 Heads
VAC Turbo Cams
CP Coated Bearings
ARP Head & Main Studs
Cometic MLS Head Gasket
Oil Pump, Seals and Gaskets all new
60 Trim T3/T4
MegaSquirt ECU
M3 Transmission
Stage 3 Clutch
Walbro 400 Fuel Pump
AeroMotive FPR
80# Injectors
You can see the build picture by picture on my Facebook Profile and Page:
https://www.facebook.com/joey.botelho.35/media_set?set=a.10150606148523316.389129.514073315&type=1
https://www.facebook.com/media/set/?set=a.10150765503327110.457120.372905142109&type=1
I hope you like the pics.
« Last Edit: May 06, 2014, 07:28:05 PM by RuthlessPerformance »
Joey
http://www.ruthlessperformancemotorsports.com/
"GOT BOOST?!?!?!?!?!?!"
Slowered318
  • -Receive: 9
    • My '91 318is
Re: Turbo M42 Build
« Reply #1 on: July 19, 2013, 08:19:59 AM »
Looks like an awesome build so far. I hope you hit that 450hp goal, that'll teach the S52 guys a thing or two.
Also, nice addition of the Volvo and Chevy style "redblock" :)
wazzu70
  • Nasty Nick
  • -Receive: 18
Re: Turbo M42 Build
« Reply #2 on: July 19, 2013, 09:52:01 AM »
That is a recipe for some success! Keep us updated :)
-Nick
91 E30 M42 with VEMS
kpjo4
Re: Turbo M42 Build
« Reply #3 on: July 20, 2013, 04:53:00 AM »
Wow that's a lot of pics but a nice build! props!!
RuthlessPerformance
Re: Turbo M42 Build
« Reply #4 on: July 23, 2013, 09:02:07 PM »
I'll post pics soon of the install!!!!
Joey
RuthlessPerformance
Re: Turbo M42 Build
« Reply #5 on: July 26, 2013, 05:23:35 PM »
Here is a Slide Show of the build. Hope you guys like
http://s5.photobucket.com/user/Masslawya/slideshow/BURT%20BMW%20318%20i
Sorry about Photobucket putting pics out of order.
« Last Edit: July 26, 2013, 05:30:34 PM by RuthlessPerformance »
Joey
ChrisPino
    • E30 318is Turbo
Turbo M42 Build
« Reply #6 on: December 17, 2013, 07:12:37 AM »
After a years of studies and planning having the car with the engine installed but running N/A setup.
I finally decided to turbocharge it during the last 3 months.
Here is my setup for a daily drive car that I'm using now.
 1- M42 Stock internals 1.8L
 2- Cometic MLS Head Gasket (0.12) + ARP HeadStuds
 3- Highly ported and polished Head
 4- Custom Made High Flow Header (42mm Internal Diameter)
 5- Custom Made Short Runner Intake
 6- 3 inch Butterfly (coming from VR6 Golf Engine)
 7- Turbine (Precision 5431E) with the new MFS compressor wheel
 8- TurboSmart Wastegate 38mm (with Downpipe screamer)
 9- Magnacore R100 (10mm Spark Wires)
 10- MegaSquirt 2 (Board Version 3 - Fuel & Spark)
 11- 3 inch full straight Exhaust
 12- Spec Stage 3+ Clutch
 13- RevShift Full race engine mounts
 14- Siemens Deka 630cc Injectors
Here is also a link for the first dyno day with the output I'm running now.
Planning to go for more boost soon as the car still have a potential for more Whp.
http://www.youtube.com/watch?v=of_LRCu_GEE
I will be happy to receive your comment and suggestions.
RuthlessPerformance
Re: Turbo M42 Build
« Reply #7 on: May 06, 2014, 06:56:51 PM »
Here are the pics:
Joey
RuthlessPerformance
Re: Turbo M42 Build
« Reply #8 on: May 06, 2014, 07:27:26 PM »
Finishing off the motor.
Joey
Darky
  • -Receive: 23
Re: BMW E36 Turbo M42 Build
« Reply #9 on: May 07, 2014, 01:45:36 AM »
Nice work!
What size pistons did you use? Did you change the crank?
Massive turbo manifold!
Must be early e36, no serpentine v belt. I thought all e36 m42 had the v belt. That looks like one out of an e30?
Cheers
RuthlessPerformance
« Reply #10 on: May 07, 2014, 08:28:55 PM »
Thank you Darky!!!  They are 84.5 MM pistons.  I'll post some more pics.
Joey
RuthlessPerformance
« Reply #11 on: May 07, 2014, 08:54:46 PM »
Joey
RuthlessPerformance
« Reply #12 on: May 07, 2014, 08:55:49 PM »
Powder Coating came out nice I think.  ;D
Joey
RuthlessPerformance
« Reply #13 on: May 07, 2014, 09:09:35 PM »
I choose to retain the stock intake, as it will flow easily in excess of 500HP, but the longer runner design will kepp the torque numbers nice for city driving. But I came to a problem, as no one makes a billet fuel rail for the stock M42 intake manifold. So we had to build a gig and make a fuel rail ourselves. We actually made 5 just in case other people needed them. The Billet Fuel Rail looks and works great, nice fit. Not sure, but we are considering powder coating it black, not sure, but I think it should be black, made even anodized?  Well here it is:
Joey
RuthlessPerformance
« Reply #14 on: May 08, 2014, 08:36:22 AM »
The Motor did come out of an E30 donor car.
Joey
