1991 - 318isSterling Silver Metallic on Anthracite Uberkaro Cloth
(Purchased Summer of 2002)
PERFORMANCE:
 135 Hp @ 6500 rpm, 130 lb/ft @ 4000 rpm
 Getrag 240 5 Speed Manual Transmission
 2650 lb. Curb Weight
 1/4 mile in 16.56 sec, @ 85 mph
MODIFICATIONS:- Re-built M42 (Port & Polished, Forged Pistons, Valve Guides and Lifters)
- MarkD "91 Octane" Performance Chip
- Bosch 19# 4 Pintle Injectors (0280150943)
- HQ Autosport COP Kit
- Brullen Custom "Header Back" Performance Exhaust
- 16" 2 Speed Electric Fan and Aluminum Shroud (80/88 Thermo Switch)
- 325ix Washer Fluid Container
- MM Lightweight Flywheel & HD 228mm Clutch
- Autosolutions Shift System
- E28 Transmission Mounts
- MM Differential (3.91, 3 Disc VLS, 288 "Medium Case")
- Falken Ziex ZE329 Tires (195/65-14)
- Brembo Front & Rear Rotors
- PBR Ultimate Ceramic / Textar "OE" Brake Pads
- ECS Tuning SS Brake Lines
- Rebuilt Calipers (VHT Gloss Black)
- IE Stage 3 Springs
- H&R Anti-roll Bars (22mm front, 18mm Rear)
- Modified e38 Rear Anti-roll Bar Links
- Koni "Yellow" Adjustable Struts and Shocks
- Rogue Engineering Rear Shock Mounts
- E46 ZHP Steering Rack (3.2 Turns)
- M3 Control Arm Bushings
- Offset Front And Rear Bushings For Camber Correction
- Eibach Strut Tower Brace
- Moulded M-Tech II Fiberglass Body Kit
- Artic Silver Paint
- Full Black Italian Leather (New Image Interiors)
- E30 M3 Antenna
- Genuine Euro BMW Grills
- Hella Smoked Ellipsoid Headlights
- Lumens HID 4300K Xenon (Low)
- Lumens Ultra White (High)
- Hella Optilux Yellow (Fog)
- Canadian DRL Delete
- Bavarian Restoration Ground Wires
- Smoked Signal Lens
- MHW Smoked Tail Lights
- Blacked out 318is badge
- M-Sport Illuminated Shifter
- Check Panel Replaced with a 3rd Dome Light
- 13 Button OBC (Need a 318 Coding Plug)
- Alpine/DLS/Eclipse Audiophile Sound System
