Slowered318 Built
Author Topic: Slowered318 Built  (Read 23000 times)
monty23psk
  • -Receive: 17
Re: Slowered318 Built
« Reply #30 on: March 22, 2014, 07:01:44 PM »
Very nice, I too plan to do the same when I paint the car, only chrom left minus the antenna and the ring around the roundels. I even have the headlight rings blacked out.
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #31 on: March 22, 2014, 10:03:24 PM »
You can always go with the M3 antenna but I'm not sure they work the greatest.
Silicon carbide sand paper, scotch brite, and self etching primer is your best friend on this project.
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #32 on: August 10, 2014, 11:00:02 PM »
For those with the (check-less) check panel that only displays a seat belt warning?
Made use of a spot that's previously only good for hiding a doobie, an old center console (for the vinyl), inexpensive materials, hours and hours of labor, and 3 of the 4 existing wires to fabricate a 3rd dome light. Yes... it be wired up to the door pin and light supervision from the keyless entry using a diode.
I agree it would be easier to mount the map lights from the vert but I find that rear view mirror is a little too bulky.
« Last Edit: August 10, 2014, 11:08:19 PM by Slowered318 »
Tgoode318
  • -Receive: 11
« Reply #33 on: August 11, 2014, 12:04:08 PM »
"made use of a spot that's previously only good for hiding a doobie" LOL, but where will the poor doobie go now?
I like your setup your interior appears to be very well lit compared to my e36 which is like a dark cave in comparison (dome light broken),  With tint i feel like i am in the bat mobile sometimes.
« Last Edit: August 11, 2014, 12:20:21 PM by Tgoode318 »
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #34 on: August 11, 2014, 07:39:11 PM »
Not overly concerned, I would much rather have the map light. The old night vision isn't what it used to be.
I didn't know the e36 had the same problem? Most BMW interiors are lit up like a Christmas tree, even lights shine on the ground when you open the doors.
« Last Edit: August 12, 2014, 02:16:45 AM by Slowered318 »
Mimikrakra
« Reply #35 on: September 27, 2014, 07:11:08 AM »
Hi, nice car ^^
http://www.m42club.com/forum/index.php?topic=18485.0
Le temps ou les hommes étaient des hommes et les femmes s'en contentaient.
Si tout parait sous contrôle c'est que tu ne roules pas assez vite.
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #36 on: October 11, 2014, 07:44:02 AM »
All this should be going in over the next few days, along with a new steering knuckle (non airbag) and e30tech conversion kit.
A long overdue rack conversion.
« Last Edit: October 11, 2014, 07:47:55 AM by Slowered318 »
Mimikrakra
« Reply #37 on: October 12, 2014, 04:24:15 AM »
Which car is this steering knuckle from ?
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #38 on: October 18, 2014, 02:39:13 AM »
Just installed Metric Mechanic 3.91 ls diff and lightweight flywheel. I'll do a writeup with pictures after some testing.
It's brand new for e30 318is (no airbag), shame I have to cut out the bolts and shorten it.
« Last Edit: October 18, 2014, 02:41:10 AM by Slowered318 »
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #39 on: May 17, 2015, 10:06:24 AM »
Hard at work on the steering rack this long weekend.
