Mimikrakra - E30 318is
Author Topic: Mimikrakra - E30 318is  (Read 26287 times)
Mimikrakra
« on: September 14, 2014, 03:28:44 PM »
Hi, i'm in the south of Paris and here is my 318is.
It's the 3rd one à home. I started my project on an other one but there were to much work so i bought this one on April 2010.
I have all it's paper since the purchase order in 1990.
A friend's 325is with a S50B32
« Last Edit: September 28, 2014, 06:18:07 PM by Mimikrakra »
http://www.m42club.com/forum/index.php?topic=18485.0
Le temps ou les hommes étaient des hommes et les femmes s'en contentaient.
Si tout parait sous contrôle c'est que tu ne roules pas assez vite.
Mimikrakra
Re: Mimikrakra - E30 318is
« Reply #1 on: September 14, 2014, 03:35:05 PM »
My old et my actual 318is :-* :'(
I still have some parts to be exchanged between the two.
Last days in the box, soon it will be sold
« Last Edit: September 28, 2014, 06:19:33 PM by Mimikrakra »
Mimikrakra
« Reply #2 on: September 14, 2014, 03:40:48 PM »
Pictures from Pola Giverola in Spain. the roads there are hummmmm que du bonheur :D
Three more from Spain
« Last Edit: September 28, 2014, 06:20:35 PM by Mimikrakra »
Mimikrakra
« Reply #3 on: September 14, 2014, 03:55:07 PM »
Little shoot on May 2011
Yellow headlightss
With some friends on July 2011. Elle a de la gueule ma voiture :P
« Last Edit: September 28, 2014, 06:21:25 PM by Mimikrakra »
Mimikrakra
« Reply #4 on: September 14, 2014, 03:58:55 PM »
In August 2011 it looked like this
Early September
December
« Last Edit: September 28, 2014, 06:23:08 PM by Mimikrakra »
Mimikrakra
« Reply #5 on: September 14, 2014, 04:03:37 PM »
July 2012 week end in St Jean de Mont
Today it look like this. Next i will show you the changes for the braques, the engine and the inside.
« Last Edit: September 28, 2014, 06:24:14 PM by Mimikrakra »
keflaman
  • -Receive: 35
« Reply #6 on: September 14, 2014, 08:41:38 PM »
Beautiful car. Welcome to the Le'Club. ;)
Darky
  • -Receive: 23
« Reply #7 on: September 15, 2014, 06:36:27 AM »
Hi and welcome
Those brakes standard? Look a bit large.
It looks like you have been with these cars for awhile, what modifications have you done?
Cheers Rohan
Mimikrakra
« Reply #8 on: September 16, 2014, 01:10:30 AM »
Hi, thanks for the welcome  :)
The front brakes are Hispec 300mmx28 and the rear are Z1 disks and M3 E30 calipers.
I didn't see you answers because no notification i will fix that :-)
« Last Edit: September 16, 2014, 01:14:37 AM by Mimikrakra »
Mimikrakra
« Reply #9 on: September 16, 2014, 12:32:40 PM »
It's a third hand and i have it since July 2010. It was very clean and didn't need any work on it but i wanted to continu my project started on the first one. I disassembled the entire car exept the dors and the trunk and i  and remove the tar covering inside.
Just a precision, i always work alone on my cars :)
Silentblocs: AKG
Rack steering: E36
Wheels: TSW Imola 7,5x16 ET20
Tire: Falken FK452 225/45 ZR16 89Y
Front Brake: Hispec 300mmx28
Rear Brake: Z1 disks + M3 E30 calipers
Engine: M42B18 stock + ship
Headlights: yellow home made + Xenon 6000k
suspension: Apex
Springs: Eibach -3,5cm
« Last Edit: September 28, 2014, 06:25:46 PM by Mimikrakra »
Mimikrakra
« Reply #10 on: September 16, 2014, 01:51:36 PM »
July 2010/
Here are my AKG silent blocs
80A
SB excentrés de triangles AV 75D
75D
80A
I bought these beautiful rims, 16x9 BROCK B3 but I sell because they do not correspond to the philosophy I want for the car. They are too heavy and too wide.
Tires, FALKEN FK452 225/45 ZR16 89Y
« Last Edit: September 28, 2014, 06:26:23 PM by Mimikrakra »
Mimikrakra
« Reply #11 on: September 18, 2014, 02:05:18 PM »
July 2010/
HiSpec 300x28mm
Rear calipers M3 E30
Before restoration
Rust treatment with electrolysis
After
The result is still not good enough for me so i'll test the destructive rust and when the result will be good I will spend one or two layers of gray.
I still miss BMW calipers repair kits (rings, gaskets) and rear Z1 disks (the same as M3 but 4 holes).
« Last Edit: September 28, 2014, 06:28:28 PM by Mimikrakra »
Mimikrakra
« Reply #12 on: September 18, 2014, 02:09:10 PM »
Here are pictures of the work on the calipers
« Last Edit: September 28, 2014, 06:30:04 PM by Mimikrakra »
Mimikrakra
« Reply #13 on: September 18, 2014, 02:36:53 PM »
August 2010/
Here are my new rims, TSW Imola 7,5x16 ET 20.
Here is an trial assembly of the TSW 7,5x16 with 205/45/16 compared to BBS 14" monted on my previous 318is.
BBS 14"
TSW
« Last Edit: September 28, 2014, 06:33:49 PM by Mimikrakra »
Mimikrakra
« Reply #14 on: September 18, 2014, 02:49:41 PM »
October 2010
This afternoon i made a test assembly of the brakes in a rim to be sure that it goes and take it out from my head.
« Last Edit: September 28, 2014, 06:35:16 PM by Mimikrakra »
