Mimikrakra - E30 318is
Author Topic: Mimikrakra - E30 318is  (Read 26288 times)
Mimikrakra
Re: Mimikrakra - E30 318is
« Reply #75 on: July 22, 2016, 11:16:35 AM »
4/04/2011:
Hi, saturday I dismount the caliper.
I will see in the week if it's good
http://www.m42club.com/forum/index.php?topic=18485.0
Le temps ou les hommes étaient des hommes et les femmes s'en contentaient.
Si tout parait sous contrôle c'est que tu ne roules pas assez vite.
Mimikrakra
« Reply #76 on: July 22, 2016, 11:23:27 AM »
05/04/2011:
This morning i dismount (again) the caliper because in the night I realized I had not removed the small piece of rubber inside.
It will cost me the price of the kit again but when i removed the seal it  had the same cut. When I handed the piston I did not force and neither the piston nor the chamber are not damaged so how does it happen?
Mimikrakra
« Reply #77 on: July 22, 2016, 11:45:44 AM »
10/04/2011:
Hi, the chassis is completely finished (without the rear right caliper)
I took the stering rod on my old direction.
The stering hoses installation is OK.
New BMW Bellows and clamps
I pulled the hood, heated the engine and the line with it's necklaces and new silent blocs and purged the direction. Without this fucking seal the brakes honing would be done lol
[/quote]
Mimikrakra
« Reply #78 on: July 22, 2016, 11:49:43 AM »
13/04/2011:
Here is a before / after
Beforet:
After:
Before:
After:
Before:
After:
Darky
  • -Receive: 23
« Reply #79 on: July 22, 2016, 05:11:25 PM »
Nice work!!
I have never seen the underneath of a e30 so colourful. Usually black or just dirty.
Does the suspension feel a lot better now? What setup are you running?
Mimikrakra
« Reply #80 on: July 23, 2016, 04:00:10 AM »
Hi, yes usually cars underneath are black and dirty. Since this i have run a few Km and it became dirty too lol
The chassis is realy good with AKG silent block and now the car has new Bilstein B8 suspension.
The stab bars are from origine because i love little roads and i don't want the car too rigid.
Darky
  • -Receive: 23
« Reply #81 on: August 17, 2016, 04:13:48 AM »
What are the new brakes I see an adaptor bracket from hi spec, but what are the brakes 4 spot?
