Mimikrakra - E30 318is
Author Topic: Mimikrakra - E30 318is  (Read 26274 times)
Mimikrakra
Re: Mimikrakra - E30 318is
« Reply #60 on: May 28, 2016, 10:59:28 AM »
Hi, Wednesday i finished the pieces to be painted so there are no more place in the room
A first cleaning test and BMW paint is good resistant.
Many thanks to RESTOM PAC 2030
before
while
After
A busy weekend
http://www.m42club.com/forum/index.php?topic=18485.0
Le temps ou les hommes étaient des hommes et les femmes s'en contentaient.
Si tout parait sous contrôle c'est que tu ne roules pas assez vite.
Mimikrakra
« Reply #61 on: May 28, 2016, 11:07:13 AM »
This afternoon I attended hoses that leave the tank.Motor those waiting until there is no engine
It's crazy how long it takes to change two hoses
Looking at the photo I realize there is a problem. Tomorrow I will loosen the clamp to return the hose properly.
Mimikrakra
« Reply #62 on: May 28, 2016, 11:10:00 AM »
From BMW
Mimikrakra
« Reply #63 on: May 28, 2016, 11:44:29 AM »
Tuesday morning i worked on the brakes. So cutting the edges of the sheet metal disk protection to let place for the 280mm Z1 disks and modification of the calipers supports
ARD
ARG
Mimikrakra
« Reply #64 on: May 28, 2016, 11:47:08 AM »
This morning I had a little bit of phosphoric acid on parts followed by cleaning with gasoline F. Here are quietly suspended pending the layers of paint tonight
Mimikrakra
« Reply #65 on: May 28, 2016, 11:50:26 AM »
I finished the parts Friday night. I've realized that my black paint is not a hot temperature paint but an exhaust brake paint. Is this serious doctor ?
Okay well it will dull, very dull but that's okay
Mimikrakra
« Reply #66 on: May 28, 2016, 11:51:49 AM »
Saturday night...
Mimikrakra
« Reply #67 on: May 28, 2016, 11:52:44 AM »
That Saturday morning at 5 am and that's all for tonight
Mimikrakra
« Reply #68 on: May 28, 2016, 11:56:46 AM »
yesterday afternoon i monted the rear train. Missing brakes and suspension.
Mimikrakra
« Reply #69 on: May 28, 2016, 11:59:11 AM »
I had not put the pictures dry M3 calipers.
keflaman
  • -Receive: 35
« Reply #70 on: May 29, 2016, 06:53:52 AM »
Wow! You've certainly been productive. :)
Mimikrakra
« Reply #71 on: July 22, 2016, 09:55:06 AM »
March, 18 2011
Finally I managed to bring the piston in. After 15 minutes I said I had nothing to lose by returning the seal and by miracle it happened almost without force, which would mean that there is indeed a mounting way of the seal.
As there is no place to spend the fingers I used a socket (which enters the piston) and an extension cord.
I took the opportunity to pass the cap of the bleeder screw and the four guides silicone like that they will nickels
Mimikrakra
« Reply #72 on: July 22, 2016, 10:34:43 AM »
March, 19 2011
Hi, this afternoon I somehow worked :D
New Handbrake jaws
I spent some silicone on the hub to prevent oxidation
Z1 disks and M3 calipers monted
Again, silicone on the face in contact with the rim
New Anti roll bar silent bloc
Silicone between the silent bloc and the anti roll bar
APEX springs
Silicone again and again
It's nice with blue and pink, no ?
I pulled the straps that secure the motor. Tomorrow the car should be on its wheels
Mimikrakra
« Reply #73 on: July 22, 2016, 10:51:54 AM »
March 20, 2011
Still some work to do...
Silent blocs extraction
eccentric silent block installation
Brakes installation
It touches here, will have to fix this
Hummmmm
Greasing
Greasing again
Not sure for this but the car will not roll yet
It's not the good steering rod. Same player play again lol
More problemes du fix lol. I'll be back
Merci
Mimikrakra
« Reply #74 on: July 22, 2016, 11:12:55 AM »
April 03, 2011
Hi, Sunday I worked a little. The chassis is almost finished, almost because of two stupid bullshits.
The first, I broke a three screws so I will command a complete set tomorrow:
The second, will purging the brakes, a leak on the rear left and it's not the bleed screw. I'm good for another refection kit from BMW ^^
The good news: The steering rack is installed. This afternoon il will command the steering rod
3 nice picts
