Author Topic: BMW E36 Turbo M42 Build  (Read 15073 times)
Darky
  • -Receive: 23
Re: BMW E36 Turbo M42 Build
« Reply #15 on: May 10, 2014, 01:27:15 AM »
That is nuts, I like nuts!
How much boost, 3 inch exhaust, comet head gasket and stage 3 clutch tells me a lot of boost?
500 hp?
Cheers
jrw21
  • -Receive: 6
« Reply #16 on: May 10, 2014, 07:43:49 AM »
Joey, nice build I really like your fuel rail. I searched everywhere for one of these finally found a company in sweden and had one imported to me. Wish you had posted sooner I would have snagged one of yours!
RuthlessPerformance
    • Ruthless Performance Motorsports
« Reply #17 on: May 12, 2014, 10:08:41 PM »
Motor can handle over 500HP easy. I think that turbo is good for 400-450HP on race fuel. An Intercooler Upgrade and a Turbo Upgrade is all this build needs!!!!
Joey
http://www.ruthlessperformancemotorsports.com/
"GOT BOOST?!?!?!?!?!?!"
RuthlessPerformance
« Reply #18 on: May 12, 2014, 10:24:35 PM »
M3 Tranny and Stage 3 Clutch Install.
Joey
Tgoode318
  • -Receive: 11
« Reply #19 on: May 13, 2014, 08:17:26 AM »
Nice work, Is there any thing special needed to get that zf tranny bolted up? And you have to modify the drive shaft as well right?
« Last Edit: May 13, 2014, 09:03:58 AM by Tgoode318 »
-'94/05 M42 Convertible
-2001 330CI M Package
-2016 M4 Competition
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #20 on: May 13, 2014, 11:07:55 AM »
The ZF bolts right up. In the E36 chassis its a direct swap with the E36 ZF shifter arm, linkage, and driveline.
In the E30 chassis the shifter arm and linkage need to be extended and you need a custom length driveshaft.
-Nick
91 E30 M42 with VEMS
RuthlessPerformance
« Reply #21 on: May 13, 2014, 06:43:02 PM »
Thranny bolted right up. We needed to make a 3/4" spacer for rear-end yoke, as the M3 Rear End is slightly longer or it could be because the tranny came out of a 6 cylinder car could account for the difference, but it was an easy fix.
Joey
RuthlessPerformance
« Reply #22 on: May 13, 2014, 06:44:14 PM »
Although I did have to modify the shifter linkage, but that only included taking 1/2 inch from another linkage to extend the one that came with the tranny.
Joey
RuthlessPerformance
« Reply #23 on: May 13, 2014, 07:16:42 PM »
Motor & Tranny Install:
Joey
RuthlessPerformance
« Reply #24 on: May 19, 2014, 08:28:57 PM »
Intercooler Piping.
Hope you guys are enjoying this build.
Joey
keflaman
  • -Receive: 35
« Reply #25 on: May 19, 2014, 08:58:23 PM »
I am.
Darky
  • -Receive: 23
« Reply #26 on: May 20, 2014, 02:25:59 AM »
I am too, but for the boost I think the inter cooler needs to be bigger!
Always wondered how you got the turbo in with the block pivoted 30 deg. Painfully!
RuthlessPerformance
« Reply #27 on: May 20, 2014, 07:25:42 PM »
Not of my choice. My opinion was Top Mount, KPA or COMP Turbo and a Spearco Intercooler about 3 times the size. Power will be limited by turbo and intercooler.
Joey
RuthlessPerformance
« Reply #28 on: May 27, 2014, 08:10:14 PM »
Coils, rear-end and exhaust
M3 X-Brace
Joey
RuthlessPerformance
« Reply #29 on: June 12, 2014, 09:55:51 PM »
Here's the Fuel System and Suspension UpGrades!!!
Fuel System:
Suspension: Voghland Springs & Bilstein Shocks & Struts:
Joey
