Author Topic: 91 318is build.  (Read 26711 times)
dakon
91 318is build.
« Reply #15 on: August 29, 2010, 02:02:22 PM »
we may have found the source of the leak!!... the rear timing case gasket...
couple gallons of brake cleaner...
Going to pick up a harbor freight parts cleaner later today, they are on sale for almost 50% off!!...
also grabbed a few random sockets that weren't on hand...
old clutch
and the new
the old clutch didn't look to bad, however the pivot pin was COMPLETELY jacked, basically worn away. So a new pivot pin, and release arm are on the way.
i don't know if you can see what was left from the pin in this picture or not...
« Last Edit: October 10, 2010, 08:19:57 PM by dakon »
dakon
91 318is build.
« Reply #16 on: September 04, 2010, 11:55:29 PM »
got the block cleaned up
during the cleaning
after the cleaning
Head gasket on the head
Getting ready to put the oil filter housing on.
cleaning some other parts, intake and the thermostat housing.
Head on the block
Rear timing case gasket
And with the rear timing case on.
Right now the head is just sitting on the block, the head bolts aren't torqued in yet, still waiting for the cam gears, and timing chain stuff. Once all that stuff comes in that phase of the assembly will continue. Both cam gears, crank gear, all the plastic guides as well as a the chain will be new.
« Last Edit: October 10, 2010, 08:18:58 PM by dakon »
91 318is build.
« Reply #17 on: September 06, 2010, 06:22:06 PM »
You should probably replace those cam sprockets while you're at it because they look rather worn!
dakon
91 318is build.
« Reply #18 on: September 08, 2010, 12:40:36 AM »
yup they shipped today from getbmw parts.. i ordered both cam sprockets, crank sprocket and a new chain.
dakon
91 318is build.
« Reply #19 on: September 08, 2010, 12:41:11 AM »
Day after Labor day delivery
9 boxes shown here, there was another that was delivered after the photo was taken....
and the opening of all the new stuff begins!
Suspension..
Brakes
Trunk spoiler, front lip, timing chain and kidneys..
the rest of the stuff for the clutch, and even more hoses.
And some more parts!!!
eventually my buddy will get is garage back... i dont think there will be many more days like today with this much arriving at one time.. Getbmwparts had 4 of our orders on back order, and i guess everything came in from Germany at about the same time?
« Last Edit: October 10, 2010, 08:18:01 PM by dakon »
91 318is build.
« Reply #20 on: September 08, 2010, 10:33:20 AM »
Wow, thats a ton of parts. This car is getting some serious lovin!!
Lemme know when you finish that suspension install, I'd love to borrow that Bilstein gland nut tool!
dakon
91 318is build.
« Reply #21 on: September 08, 2010, 11:46:29 AM »
as one of our facebook friends said, "Damn thats gona be a brand new car when you get it all back together"
and it pretty much will be.... the paint will probably be addressed next year though..
i Forgot the 4.10 LSD out of an E30 M3 that i got......
and the inside
« Last Edit: October 10, 2010, 08:17:08 PM by dakon »
Bunta
91 318is build.
« Reply #22 on: September 08, 2010, 08:27:20 PM »
Awesome job man
Really looking great
I bet the delivery man knows you well
Have fun
Hunter
autox320
91 318is build.
« Reply #23 on: September 09, 2010, 01:26:16 AM »
Looking really really good!
Hmm race springs and track pads....going somewhere?:)
I actually had a delivery guy thank me for business. We're a good 20min in the boonies so he says made some extra time with drops our way.
dakon
91 318is build.
« Reply #24 on: September 09, 2010, 11:21:06 AM »
Quote from: autox320;96345
actually they are just HP sports.. not HP blues.....
lets just say i want this car to be Very enjoyable to drive. :D
dakon
91 318is build.
« Reply #25 on: September 10, 2010, 11:10:28 PM »
the latest update!!.
have a couple drawers with 318 parts....
new and old oil pressure relief valve items.
getting ready for assembly...
new and old cam gears..
Head with cam locks.
torquing the head on.
And the oil pressure relief valve.
 almost together
closer!!
And in all her glory...
« Last Edit: October 10, 2010, 08:16:22 PM by dakon »
cristimm
91 318is build.
« Reply #26 on: September 11, 2010, 05:57:25 AM »
Quote from: dakon;95753
WoW, Grease and slime?!?!?!?!
Not any more!!!
What did you used to clean it so good?
dakon
91 318is build.
« Reply #27 on: September 11, 2010, 11:13:11 AM »
pressure washer VERY carefully.
Petebee
91 318is build.
« Reply #28 on: September 11, 2010, 03:51:45 PM »
Great job...your car is going to be awesome when complete. What suspension springs did you go with?
dakon
91 318is build.
« Reply #29 on: September 11, 2010, 10:17:11 PM »
H&R race springs.
