Author Topic: my low $$$ turbo build  (Read 20283 times)
318e30
« on: July 01, 2010, 06:22:07 PM »
I just picked up my 91 e30 318is a few months ago traded it for a 97 supercharged miata. So in need of more power didnt want to do the whole m/s50 swap i saw all the turbo builds & how ez it was so i said why not.
parts:
m50 turbo manifold $120
delta fin FMIC 28x7x2.5 2.5 inlets $65
JDM sports t3/t4 $80
Turbonetics raptor bov $80
Prosport boost gauge $50
Autometer a/f gauge $ free
oil lines $50
3" turboback $120
30 lbs injectors from turbo volvo $ free
FMU $ free
Snow Performance water/meth. injection stg. 1 $150
t-bolts clamps, silicone hoses & misc. $150
total build under $1k
custom made adapter for the AFM made by Tony Excel fabrication
oil feed from oil filter cap
turbo to manifold 50* adapter stainless made by Beto @ b-werks
getting piping done
all done i've put about 2k miles no problems yet besides my clutch
so i did the m20 flywheel with sachs h.d. clutch
idles perfect runs strong i have it at 8 psi good numbers on the wide band 14.7 idle 12.3 under boost i bumped it up to 10 psi but leaning out so waiting for my Miller Performance W.A.R. chip
t3/t4, 9 psi., m20 flywheel & Sachs clutch, Snow water/methanol injection, Ireland springs, bilstein sports, ate rotors & hawk pads, AC Schnitzer kit, Recaro seat
jscribble
« Reply #1 on: July 01, 2010, 08:44:26 PM »
Awesome. This is almost exactly what I want from my car. Definitely want to take oil from the filter canister. Interested in the W.A.R. chip too.
Pretty easy to set up the water injection? Did you buy the kit new?
Betty - Sold
Sabine - 2004 325xi
Esprit Aviation
« Reply #2 on: July 01, 2010, 09:55:25 PM »
Very nice set-up! and inexpensive as well. Please keep us posted on any further improvements, although it appears that it is nicely dialed-in already. Congrats!
thedguy
« Reply #3 on: July 01, 2010, 10:51:35 PM »
So is all your fueling just being handled by the 30lb injectors and the stock ecu?
318e30
« Reply #4 on: July 01, 2010, 11:59:48 PM »
yeah stock ecu, 30 lbs injectors & fmu i have a fuel pump i need to install next.
i got the water/meth. used on eBay $150 this is the 3rd Snow performance kit we've gottin off of eBay they work awesome !!! new $350+. the kit is so ez to install it activates off of boost.
one more thing is i kept my A/C on the car i love it next would be 3.73 lsd
« Last Edit: July 02, 2010, 12:02:01 AM by 318e30 »
clutchkick
« Reply #5 on: July 02, 2010, 12:04:39 AM »
what turbo volvo did those injectors come from?
bmwconnect
« Reply #6 on: July 02, 2010, 12:17:40 AM »
Quote from: 318e30;94162
Can you give me some insight into how you got your car to run on 30LB injectors by simply swapping out the stockers
Also do you have the part # of the injectors
thanks
« Last Edit: July 02, 2010, 12:22:48 AM by bmwconnect »
Midnight YouTube Channel
thedguy
« Reply #7 on: July 02, 2010, 12:32:00 AM »
Quote from: bmwconnect;94164
thanks
He's got an FMU... I'm guessing a vortec unit as they are the most common
dkbmxer002
« Reply #8 on: July 02, 2010, 12:44:53 AM »
m50 manifold? more info? where did you get it? i don't know much about those...
bmwconnect
« Reply #9 on: July 02, 2010, 12:48:01 AM »
Ahh yes I was thinking he was just using a rrfpr alone but now I see those kits and they come with adjustable unit also
318e30
« Reply #10 on: July 02, 2010, 01:09:14 AM »
Bosch # 0280150785 96 turbo volvo 850 i believe
it runs perfectly fine with stock ecu, 315cc & FMU my car has 178k miles i just drove it to Laughlin NV. from Fontana CA used up 1/2 tank thats 250 miles 1 way going 80-85 mph thats about 35+ mpg
318e30
« Reply #11 on: July 02, 2010, 01:15:43 AM »
yeah you can use an adjustable 1 like jackson racing, bell eng., cartech or somthing of that nature theres a ton of them out there
thedguy
« Reply #12 on: July 02, 2010, 02:08:29 AM »
wait... You wouldn't happened to have been to Adam's in recent history talking about turboing a 318 would you?  Mind pm-ing me your aim address, I'd love to talk to ya there.
bmwconnect
« Reply #13 on: July 02, 2010, 07:45:52 AM »
Quote from: 318e30;94171
yes I just wanted to get the point across that you can't simply swap in 30lb injectors and the ecu magically compensates for them... you have clearly lowered the fuel rail pressure
318e30
« Reply #14 on: July 02, 2010, 11:20:32 AM »
i havnt touch my fuel pressure other then the fmu ADDING fuel pressure under boost so the ecu will compensate for the amount of air. just to put the point across. everyone running 24 lbs ive seen have been leaning out @7-8 psi
