Author Topic: my low $$$ turbo build  (Read 20267 times)
bmwconnect
« Reply #15 on: July 02, 2010, 02:02:05 PM »
Quote from: 318e30;94202
i havnt touch my fuel pressure other then the fmu ADDING fuel pressure under boost so the ecu will compensate for the amount of air. just to put the point across. everyone running 24 lbs ive seen have been leaning out @7-8 psi
Those injectors you have put in are flow rated at 29LB@57psi... That mean's that your at a flow rate of 24LB@43.5 with the M42 at idle... If you were to swap in 30LB@43.5 rated injectors the car would simply not run. Motronic can compensate for a maximum flow rate of 24@43.5psi  injectors MAX~
Don't believe me ?
Look up your injector part number here
 http://users.erols.com/srweiss/tableifc.htm
« Last Edit: July 02, 2010, 02:10:09 PM by bmwconnect »
Midnight YouTube Channel
thedguy
« Reply #16 on: July 02, 2010, 09:45:39 PM »
which fmu did you use?  Whats the rating on it?
318e30
« Reply #17 on: July 03, 2010, 01:42:11 AM »
not sure on the fmu i got it for my miata years ago its a no name i think its a 12:1 but what ever ill have my W.A.R chip with 440cc 14 psi. hopefully by next month
t3/t4, 9 psi., m20 flywheel & Sachs clutch, Snow water/methanol injection, Ireland springs, bilstein sports, ate rotors & hawk pads, AC Schnitzer kit, Recaro seat
dkbmxer002
« Reply #18 on: July 03, 2010, 11:16:58 PM »
any info about the manifold..?
thebutcher37
Tsss..
« Reply #19 on: July 04, 2010, 12:34:57 AM »
you give me great hopes!...:D
jou ma se poes in \'n fishpaste jar.
318e30
« Reply #20 on: July 04, 2010, 12:31:00 PM »
ebay m50 turbo manifold i got mine for $120 shipped you cut down the last two cylinders & cap the end
then make an adapter to let the turbo clear the valve cover
dkbmxer002
« Reply #21 on: July 04, 2010, 12:39:55 PM »
thanks, i never knew that would work!
318e30
« Reply #22 on: July 04, 2010, 01:20:53 PM »
yeah beats paying $700 for a 666 fab. manifold or $400 for a obx one
btw i like the camaro NICE what's your et.
« Last Edit: July 04, 2010, 01:27:08 PM by 318e30 »
318e30
« Reply #23 on: August 15, 2010, 08:37:26 PM »
Update
blown turbo eBay crap
blown rings pistons 1 & 4
Lol oh well 180k bound to happen
10psi freeway run with supercharged M3
It was fun ;-)
dkbmxer002
« Reply #24 on: August 15, 2010, 11:11:24 PM »
giggaty. i really wanna do something similar..
dkbmxer002
« Reply #25 on: August 15, 2010, 11:25:43 PM »
Quote from: 318e30;94272
sorry, i completely missed this post. it has run mid 6's in the 1/8 on it's last setup with 2 cyl's fucked up. the new setup is trick flow heads and a bigger cam and not a hurt motor lol
persianbmw
« Reply #26 on: August 16, 2010, 01:54:38 AM »
do u have a link to the exact fmu, ur using. i attempted using the dasc rrfpr and it was worthless.
sorry to hear u blew ur motor. built it bigger lol.
also did u do all the welding yourself? how did u go about sourcing the gaskets u needed?
mr.vang
« Reply #27 on: August 16, 2010, 09:54:25 PM »
subscribe! ...not bad for under 1000G
fs: air bag model knee panel, bmw tools, ects
Aus-m42turbo
« Reply #28 on: August 17, 2010, 08:21:42 AM »
Sorry to hear, atleast you were having fun at the time :)
Looking on the bright side, now you have a perfect excuse to buy some low comp forged pistons, and up the boost some more!!
You mentioned the use of the OBX manifold, from what i can see they are for the e36's? Would they fit e30? As in would the turbo clear the shock tower? Im very close to buying a manifold, and as good as the 666 look im just finding it hard to part with close to $1000 (adding postage to Australia).
« Last Edit: August 17, 2010, 08:23:57 AM by Aus-m42turbo »
318e30
« Reply #29 on: August 21, 2010, 12:17:12 PM »
The fmu is most likely eBay I got it on Craigslist years ago
The turbo manifold is a eBay m50 cut down bolts right up
Yeah gonna do a mild build now rods, wiseco rings, cometic gasket, acl race bearings, regrind cams turbo spec, & tuned
