Author Topic: COP Brackets: Your Preferences?  (Read 81097 times)
xsjado
« Reply #210 on: June 23, 2010, 08:57:12 AM »
thanx...gonna try to source the parts in the near future...
iron-H
    • http://mein.auto-treff.com/5908-1.bmw
« Reply #211 on: July 13, 2010, 06:45:45 AM »
Hi Guys...
Today im going to do it.
Im driving an 1994 e36 Compact und try to take a notice which cabels we have to connect with and post it if i can finish it!
One more question:
Is it wright that the plate hold down the coils on the sparkplugs?
The old plugs clip on it but the new ones doesnt... is that the same thing what you all regonize too?
sry for that bad english :eek:
iron-H
« Reply #212 on: July 13, 2010, 06:55:06 AM »
Quote from: rob_e30;93825
It's plug and play for E30 M42's and early E36 M42's.  If you have 4 coil connectors in your harness then you are good to go.  If you have an E36 with the single round connector then you need to make up a new harness or splice into your existing.
Check out http://www.hqautosport.com for more information.
Hey Rob. Where are more informations about the wireing? Cant find it.
romkasponka
« Reply #213 on: July 13, 2010, 08:13:15 AM »
E30 318is M42
E36 318is M44
iron-H
« Reply #214 on: July 14, 2010, 04:35:39 PM »
What do you really mean?
Those instead we all use now? if how to install?
romkasponka
« Reply #215 on: July 15, 2010, 08:59:09 AM »
Quote from: iron-H;94621
I mean you do not nead any adapter plate with newer ignition coils and they are cheap even new. Problem is that you need connectors new or used. I wiil use these I think, it's more simple and lighter.
E30 318is M42
E36 318is M44
rob_e30
« Reply #216 on: August 09, 2010, 12:57:25 PM »
Great news... we built and tested an E36 Plug & Play prototype. It worked like a charm! We are collecting the materials to produce both a PnP kit, as well as a less expensive kit that requires a modification to the harness.
rob_e30
« Reply #217 on: August 10, 2010, 12:50:21 PM »
Quote from: iron-H;94598
No details on the new kit yet, we just built and tested the first one.  It's pretty ugly so no pics :).
You basically unscrew the ECU from the existing coil pack, install the new harness, coils, and plate, plug the new harness into the coils, and start the car.
E30PQ
« Reply #218 on: September 02, 2010, 11:01:54 AM »
Quote from: rob_e30;95416
Here are some photos of the first pre-production unit.  The production units will look like this.
We are very close to launching this product on our website.
cristimm
« Reply #219 on: September 03, 2010, 04:14:10 AM »
Very nice harness. :)
Bl0mgren
« Reply #220 on: May 04, 2011, 04:39:32 PM »
does a 6mm plate work?
i have missfiring and not running on all cylinders after cop conversion :(
« Reply #221 on: May 04, 2011, 07:07:56 PM »
Are you sure the coils are matched up right?  1-2-3-4 coil plugs to 1-2-3-4 cylinders to the right DME wires?  I don't have the Motronic pinout handy, but it's out there.
The coil sticks also may not be contacting the plugs.
Bl0mgren
« Reply #222 on: May 08, 2011, 02:27:26 PM »
Right firing order. Thats why i ask if 6mm works, if coil stick get contact :confused:
nanotech9
« Reply #223 on: June 27, 2011, 01:37:28 PM »
i just made my own bracket using the PDF i found on the net (google searched the file name) and a set of 330i coils on ebay for $46.
Cut up the aluminum plate and used a vertical Mill at work with a DRO to get all the holes in the right place.  Easy as pie!
Worked great!
\'91 318is : J/C chip, Koni\'s / H&R\'s, big sways F/R, homemade strut tower brace, COP conv., BOSCH 4p injectors, intake cam advance
\'99 528i
\'05 R1200GS
« Reply #224 on: June 27, 2011, 05:14:33 PM »
If I didn't have one already I'd be PM'ing you right now...
That and a few intake mods I've been thinking of...
