Author Topic: COP Brackets: Your Preferences?  (Read 81086 times)
« on: August 04, 2006, 12:24:57 AM »
8/10/07 Update
I am presently in process of making 8 more brackets.  Thus far, 7 are claimed.  Anyone want #8?
I also updated the technical drawing for the plate, cutting it down to 1 page with more clean dimensions.  It is here:
http://www.e30tuner.com/coilonplug/M42_COP_BRACKET_A1.PDF
End 8/10/07 Update
« Last Edit: August 20, 2007, 02:29:17 PM by bmwman91 »
mikesjo
« Reply #1 on: August 04, 2006, 02:47:15 AM »
What does that do exactly?
« Reply #2 on: August 04, 2006, 09:56:35 AM »
The bracket allows you to move the ignition coils directly over the spark plugs.  This eliminates the plug wires which are costly to replace, and increase the chance of cross-arcing which can cause misfires.
I guess I should also mention, this bracket is NOT for the stock M42 coils.  It is for this type:
http://www.turnermotorsport.com/html/detail.asp?PRODUCT_ID=2310
If you are referring to the arm thingy, that is for you to secure the harness to so that engine vibrations do not cause the wire to undergo a fatigue failure at the connectors.
FL318is
Whew!
« Reply #3 on: August 04, 2006, 10:47:56 AM »
I have got alot to learn.  I won't even tell you what I thought they were for!
haledj
« Reply #4 on: August 04, 2006, 12:40:00 PM »
Quote from: FL318is
I want to know... I didn't know what they were for either:)
« Reply #5 on: August 04, 2006, 09:15:58 PM »
Yeah I kinda wan to know too.  Embarassing n00b thoughts or BAN!  Lol, I hope I don't turn this into Bimmerforums OT.
Coil Price.
« Reply #6 on: August 05, 2006, 05:57:05 PM »
$25 for those coils is an incredible price. Is that the regular price from Turner?
nickmpower
« Reply #7 on: August 05, 2006, 08:19:04 PM »
thats for one used coil i think
« Reply #8 on: August 05, 2006, 11:02:03 PM »
It is $25 for one.  They are used ones from cars that got upgraded coil packs I believe.  Seeing as how our coils are 15 years old and generally still work fine, I have no qualms about buying these newer used ones.
sheepdog
  • Site Admin
« Reply #9 on: August 05, 2006, 11:16:07 PM »
Does this require wire changes or anything?
« Reply #10 on: August 06, 2006, 01:41:44 AM »
Well, you COULD leave the harness untrimmed, but I think it would look shabby, and possibly be a hazard.  Though a little bit of a pain, the writeup I posted in the first post covers the process.
Repeated:
http://bmw.e30tuner.com/articles_condis1.php
tim_s
« Reply #11 on: August 06, 2006, 05:28:25 AM »
bmwman, these still available? been abroad for a month and not checked on here! can the plastic BMW cover go over these? can you send me a bracket to the uk? im in no rush as have a million and one things to do before this but wouldnt want to miss out!
« Last Edit: August 06, 2006, 05:34:49 AM by tim_s »
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
twinpop171
« Reply #12 on: August 06, 2006, 07:51:04 AM »
Nice!!!
BMWMan, I wish you had these available before I dropped $85 on new plug wires!
BTW will the BavAuto HP coils bolt to the bracket too?  That's what I 've got.
Dan.
Brillantrot 1991 318is
e9nine
« Reply #13 on: August 06, 2006, 08:08:04 AM »
Awesome write up man! Please correct me if I am wrong but is this an accurate summary of this process?
-- Buy 4 used coil packs from TMS
-- Buy your adapter plate
-- Disassemble the stock harness at connectors
-- Lengthen the harness
-- Reassemble the connectors
-- Trim harness
-- Wrap finalized harness in heat shrink & Secure harness @ cylinder 4.
« Reply #14 on: August 06, 2006, 11:52:54 AM »
Quote from: e9nine
-- Install bracket & Coils
-- Cut outer sheathing on harnesses as needed to reach coils
-- Disassemble the stock harness at connectors (1 at a time)
-- Place wire along intended path, leaving enough that the wire can reach past the coil's connector port
-- Shorten the harness
-- Wrap finalized harness in heat shrink* & Secure harness @ cylinder 4
*Heat shrink tubing could work, but tends to get very stiff and brittle.  I opted for some 3M Super 88 electrical tape (or any other rated to 210C+).
Corrected :p
