DISCUSSION
General Topics
Shot in the dark concerning an ICV.
Topic: Shot in the dark concerning an ICV. (Read 3342 times)
Thurber
June 17, 2009, 09:42:06 PM »
To repeat myself, this is a shot in the dark, but is there a cheaper solution to paying ~$175 for a new ICV--an alternate solution?
Perhaps I just have to face the facts...
"You become what you think about."
-Earl Nightingale
Administrator
Legendary
-Receive: 60
Lives in the 80s
June 17, 2009, 10:25:38 PM »
I heard a rumor once that someone was taking them apart and fixing them. Not sure though...let me check.
Hodge
June 18, 2009, 06:53:40 AM »
Spray the innards with carb cleaner...did that to both ICV's in my E30 and in my E36 and it worked wonders.
Unless it''s toast, it will work nicely.
1995 E36 318isc
Thurber
June 18, 2009, 03:36:48 PM »
hm... sounds like a good start thanks. How could I tell if it's completely blown?
-Earl Nightingale
Blip Bavarian
Jr. Member
June 18, 2009, 05:04:05 PM »
there is a guy on R3V parting out an M42. You could prob get a decent deal there. Here's a link.
http://www.r3vlimited.com/board/showthread.php?t=138537
GL
Administrator
Legendary
-Receive: 60
Lives in the 80s
Reply #5 on:
June 18, 2009, 09:29:44 PM »
You can use a 9v battery to test, but I don't recall which pins to test. It's on here somewhere but I can't find it.
carlos318is
Sr. Member
Reply #6 on:
June 19, 2009, 04:27:15 AM »
I would be interested in this as the ICV on my other halfs E36 318is has been playing up for ages and it only seems to play up when cold I have cleaned it with carb cleaner and it will work for a bit and start to play up again:(
beemer1
Jr. Member
-Receive: 1
Reply #7 on:
June 19, 2009, 12:07:49 PM »
I use to clean it once a year until I found out I had a bigger problem that was causing the idle problem, those damn vacuum hoses. Ever since I fixed the (many) air leaks my problem never returned and the ICV stays clean.
carlos318is
Sr. Member
Reply #8 on:
June 19, 2009, 06:07:06 PM »
Thanks beemer1 I will have a look and see what I can find
DISCUSSION
General Topics
