Author Topic: Shot in the dark concerning an ICV.  (Read 3344 times)
Thurber
« on: June 17, 2009, 09:42:06 PM »
To repeat myself, this is a shot in the dark, but is there a cheaper solution to paying ~$175 for a new ICV--an alternate solution?
Perhaps I just have to face the facts...
"You become what you think about."
-Earl Nightingale
« Reply #1 on: June 17, 2009, 10:25:38 PM »
I heard a rumor once that someone was taking them apart and fixing them.  Not sure though...let me check.
Hodge
« Reply #2 on: June 18, 2009, 06:53:40 AM »
Spray the innards with carb cleaner...did that to both ICV's in my E30 and in my E36 and it worked wonders.
Unless it''s toast, it will work nicely.
1995 E36 318isc
Thurber
« Reply #3 on: June 18, 2009, 03:36:48 PM »
hm... sounds like a good start thanks. How could I tell if it's completely blown?
-Earl Nightingale
Blip Bavarian
« Reply #4 on: June 18, 2009, 05:04:05 PM »
there is a guy on R3V parting out an M42.  You could prob get a decent deal there.  Here's a link.
http://www.r3vlimited.com/board/showthread.php?t=138537
GL
« Reply #5 on: June 18, 2009, 09:29:44 PM »
You can use a 9v battery to test, but I don't recall which pins to test.  It's on here somewhere but I can't find it.
carlos318is
« Reply #6 on: June 19, 2009, 04:27:15 AM »
I would be interested in this as the ICV on my other halfs E36 318is has been playing up for ages and it only seems to play up when cold I have cleaned it with carb cleaner and it will work for a bit and start to play up again:(
beemer1
« Reply #7 on: June 19, 2009, 12:07:49 PM »
I use to clean it once a year until I found out I had a bigger problem that was causing the idle problem, those damn vacuum hoses.  Ever since I fixed the (many) air leaks my problem never returned and the ICV stays clean.
carlos318is
« Reply #8 on: June 19, 2009, 06:07:06 PM »
Thanks beemer1 I will have a look and see what I can find
