Author Topic: changing gearbox oil  (Read 2259 times)
a.12912
« on: March 16, 2009, 12:21:37 AM »
spent an afternoon replacing all shift linkages and blown clutch master-cylinder, so wile i was under there i figured I'll do the box oil also.
problem being the big 17mm inverse hex nut / allen bolt wont budge!!
any ideas how to get the thing to move??
cheers
xwill112x
« Reply #1 on: March 16, 2009, 01:56:31 PM »
vice grips work well, get someone extra to push on those while you work with the ratchet.
Ich liebe meinen E30
P. Kennedy
« Reply #2 on: March 16, 2009, 06:24:00 PM »
When my ratchet handle alone doesn't allow enough leverage, I have a galvanized pipe maybe 2 ft. long and large enough in diameter to slide over the ratchet handle.  Leverage = Good.  Let physics work for you!
If my 2 ft. pipe doesn't do it, I have 5 ft. barbell handle that I can secure onto a breaker bar.  That has never failed me.
Jimmy Lewis
« Reply #3 on: March 16, 2009, 06:48:51 PM »
Penetrating lube and leverage are your friend. I think I used a 17mm nut I had laying around, stuck it in a shallow socket and just used a 1.5ft breaker. It came out fine for me, but if it did give me trouble I would have broken out the 3ft breaker bar and some penetrating lube, always does the trick.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
