Author Topic: Ultimate budget build.  (Read 82581 times)
bearsbmw
« Reply #60 on: December 01, 2008, 01:03:17 AM »
OBX has a port for external wastegate or atleast the one I saw on ebay... I couldnt get the wastegate to fit for my life so I ended up making a longer rod and useing the chain case bolts to mount a bracket for the acuator
ajatya2
« Reply #61 on: December 01, 2008, 01:26:52 AM »
oh i seee. hey man if you dont mind would u post a pic of your set up so we can have a idea as to what we should be looking for. and btw i think thats sweet 7psi and no offical tune. u rase the fule press, get new injectors at all or retard the ignition or is it all stock set up? bc thats amazing if your getting no detination with a stock setup. and im almost worried that ill try to do the same and just have bad luck with it and blow mine to pieces lol
94\' E36 318is
ajatya2
« Reply #62 on: December 01, 2008, 01:29:37 AM »
By the way Danny707 mad props for pulling/atempting to pull this off. That manifold is the greates thing ive ever seen! lol some true budget stiff right there!
94\' E36 318is
E30nate
« Reply #63 on: December 08, 2008, 12:43:08 AM »
Quote from: nuvolarossa;61756
copy-paste from another forum:
TC05-12A (Mitsubishi G63B)
Also from the early ‘80s is the TC05-12A turbocharger as used on the 2.0 litre G63B powered Mitsubishi Starion.
In standard form, the G63B turbo engine makes anywhere from 110kW to 125kW - depending on spec and market. We’d be comfortable using the TC06-12A for up to 150kW but, again, this turbo is only air-cooled so don’t expect tremendous durability.
The compressor inlet is 53mm diameter and the discharge nozzle is flared to around 54mm. The turbine passage is 46mm diameter and the 4 bolt mounting flange measures a 99 x 77mm. The dump pipe is a simple 3 bolter.
This might be a bolt-on for some Mitsubishi engines, but be aware that it another aging design.
_______________________________________
other infos: http://starion.mrbdesign.com.au/turbos.html
http://zilvia.net/f/tech-talk/171687-mitsubishi-turbo-tc05-12-map.html
http://www.cityturbo.com/forums/viewtopic.php?p=15824&sid=a88a9a88ac80c80750bafa4dfbf5e245
that all depends on what starion you have. in the links you provided, it doesnt show starions in the US. my lttle brothers 86 starion has a water cooled td05-12a, they switched from the 11a in 85. the 12a spools very quickly. my little brothers spools to 7psi at around 2k rpms. and the US starions have a 2.6l g54b engine.
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
« Reply #64 on: December 17, 2008, 09:45:53 AM »
subscrd.
wow
nice going.
Ron.
WowMom
BTRA!
Danny707
« Reply #65 on: December 30, 2008, 02:18:52 AM »
So, a little update: everything is bolted in.
Just need to run oil and coolant lines tomorrow as well as work out a down pipe and she'll be up and running.
I have to say thanks a bunch to E30Nate, his brother Dan and Tim (wtfgerman)
I couldn't have done anything without them.
johnwoo
« Reply #66 on: December 30, 2008, 03:48:24 AM »
holy fuck that's badass
Danny707
« Reply #67 on: December 31, 2008, 03:18:50 AM »
IT RUNS AND DRIVES!
Idling:
Driving:
I'm only boosting about 5-6 psi right now and thats all I can get out of the wastegate actuator as it sits, because its at a weird angle.
But I think I'm in love.
I have to say thanks a million to Nate, (e30nate), His brother Dan, Tim (wtfgerman) and Justin, (stanksbeamen) because they honestly did a hell of alot of work on this car, way more than I did.
There are a fit issues such as hood fitment because of the routing of the oil feed line and I need to route a diverter valve and replace a few vacuum hoses, but that will all get done tomorrow.
JP 91iS
« Reply #68 on: December 31, 2008, 12:28:47 PM »
Damn! Congratulations Danny and nice work.
-JP
Project M42: generating funds
Danny707
« Reply #69 on: December 31, 2008, 12:31:48 PM »
Thanks man!
I appreciate it.
If anyone would like pictures of anything specific, lemme know and I'll take some.
Hodge
« Reply #70 on: December 31, 2008, 12:42:30 PM »
Congrats Danny!
I am really interested in better videos (hehe), but mostly interested in your whole oil feed/return setup!
1995 E36 318isc
Danny707
« Reply #71 on: December 31, 2008, 12:52:30 PM »
I'll take some pics for you today Hodge, I'll post up here.
Danny707
« Reply #72 on: December 31, 2008, 10:27:04 PM »
Ok so my oil lines are kinda meh.
So I'm going to clean them up this weekend and get some good pictures then.
Kingsly
« Reply #73 on: January 03, 2009, 03:45:22 AM »
Nice work! How quickly does that tiny turbo spool?
Danny707
« Reply #74 on: January 03, 2009, 01:27:08 PM »
Its fully spooled at 3500, a little later than I thought but meh, its ok.
