Author Topic: Alternator failure  (Read 6771 times)
dark_islight
Alternator failure
« on: November 08, 2008, 04:31:46 PM »
Last year my alternator decided to give up the ghost. There was little or no warning just everything started to go dim until the car stalled out and rolled to a halt.:mad:
Today almost a year later I was cleaning out the garage and found that old alternator so I removed the regulator/brush assembly and this is what I found.:(
As you can see from the images the upper brush is worn to limits and the lower brush has 50% more material still left. I suppose the upper brush lost its contact and therefore failed to charge the battery.
I read somewhere on the net there is a $8.95 fix for the worn brushes by using power tool replacement brushes sanded down to the proper size and resoldered into place.:D
Sounds like a future project.:eek:
dark_islight
///m42 sport
Alternator failure
« Reply #1 on: November 25, 2008, 06:30:37 PM »
I second everyone checking their voltage regulator.  Thats what left me stranded out in the cold.
http://m42club.com/forums/showthread.php?t=7320
doitover
  • -Receive: 2
Alternator failure
« Reply #2 on: November 26, 2008, 08:23:39 AM »
Thanks for the post, I didn't know any alternators had those as servicable parts.
That whole assembly can be gotten from Pelican Parts for $26. Probably worth the extra money to not have to mess with the sanding and soldering.
Alternator failure
« Reply #3 on: November 28, 2008, 11:56:06 PM »
Yeah, that can be a pain.  Always likes to go at inopportune times.  Definitely DIY repairable, either McGuyver style, or with a new replacement unit.  The rectification diodes inside like to crap out, too and I have had mine rebuilt & cleaned up for $100.  Good as new!
///m42 sport
Alternator failure
« Reply #4 on: November 30, 2008, 02:54:36 PM »
what are the rectification diodes?  They just need to be cleaned out?
///m42 sport
Alternator failure
« Reply #5 on: November 30, 2008, 03:00:28 PM »
I was wondering what other cars with bosch alternators have the same voltage regulator. I was just checking on a 98 cabriolet bosch which was priced at $60 on pelican yet looks exactly the same as the regulator on my 91 318is bosch unit. Maybe there are cheaper regulators based on the car?
  • -Receive: 5
Alternator failure
« Reply #6 on: November 30, 2008, 03:28:52 PM »
Quote from: ///m42 sport;61977
I installed a voltage regulator which was originally meant for my GFs 89 volvo 240 on my M42. It was identical and it works great. $23
http://www.fcpgroton.com/product-exec/product_id/17878/nm/1985_1993_Volvo_240_Aftermarket_Voltage_Regulator/category_id/112
With a little work im sure you'll find an even cheaper one.
« Last Edit: November 30, 2008, 03:36:17 PM by tjts1 »
Cobra Jet
Alternator failure
« Reply #7 on: January 08, 2009, 10:44:59 AM »
Yep, 99% of the time, if the alternator has not seized internally, the quick fix to a "dead" or non-charging alt is replacing the voltage regulator...  Most new voltage regulators do come with new brushes, while sometimes you can find the brushes separately, for the price of a new regulator w/ brushes, it's not worth the time or $$$ keeping the old reg & just installing new brushes.  This is at most a 30-40 minute repair, depending on your repair skills & tool availability...
Most shops will try to get the owner to buy a new alternator - after all, it's more $$$$ for them - when in fact the only issue is a $20-$50 voltage regulator that has beat/worn out brushes...  Those owners that don't know about just replacing the volt reg will get hit with a nice shop bill (considering most new alternator range from $150-$300+...), excluding the labor charges...
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
