Single Row Chain
Author Topic: Single Row Chain  (Read 13369 times)
JP 91iS
Single Row Chain
« Reply #30 on: October 23, 2008, 01:44:54 PM »
Quote from: marko;59326
I just ordered the single timing chain conversion from MM.
its $250 - but I did send them my old chain + cam sprockets + crank sprocket as cores - so I'm hoping to get a discount.
Nice, thanks.  $250 isn't that much more than it would cost to buy stock replacements for the chain and sprockets.
-JP
Project M42: generating funds
marko
Single Row Chain
« Reply #31 on: October 24, 2008, 07:15:57 AM »
yes, correct, it is not so bad... $250 is a long drinking weekend, sometimes :)
Quote from: JP 91iS;59340
DASC/3.45 LSD/Billstein Sport Shocks
BavAuto Lowering Springs/Stromung Exhaust
DS1\'s/X-Brace/Front & Rear H&R Sways
JP 91iS
Single Row Chain
« Reply #32 on: October 30, 2008, 07:23:02 AM »
Here is an email I got back from MM, just a confirmation of what marko told us.
Quote
Hi JP - gosh we appreciate your email inquiry but sure do regret this delay.
Jim looked your message over and said that we could do this conversion kit for you
BUT - you'd have to send us your sprocket. Price would $250.
Let us know if you have other quesions.
Sincerely, Mary Rowe
-JP
marko
Single Row Chain
« Reply #33 on: October 31, 2008, 05:43:19 AM »
here is complete catalog of goodies from metric - as well as their price list on the bottom...
its soooo hard to keep your money in your pocket - when there is so much good stuff there.. I'm into them for about 4K already. :D
http://www.metricmechanic.com/pdfs/metric-mechanic-m42-and-m44-engine-booklet.pdf
odbod
Single Row Chain
« Reply #34 on: February 03, 2009, 08:10:10 AM »
I've done a bit more digging an this subject, the BMW chain is a european duplex standard chain spec is 06B-2, 06B=3/8" pitch, -2=duplex chain. Based on this being a standard chain then you can go to most engineering suppliers and order a simplex (single row) version of the same thing. The IWIS catalogues suggests that it is a 120link chain, but I need to count this to be sure. I called a local distributor and the most expensive, durable and strongest chain on the market today is a Renold Synergy chain, which would outlast any OEM chain, a Synergy Simplex 06B-1 Chain in the UK comes in at £42.53+VAT @ 15% which is expensive, but not a huge amount, and I'm sure it could be found cheaper... This is made and riveted to length, not using a removable link (although emold claim their removable link is ok) You should be able to get one made locally in the US too.
http://www.renold.com/nmsruntime/saveasdialog.asp?lID=426&sID=942
e30guydownunder
Single Row Chain
« Reply #35 on: February 08, 2009, 05:17:01 PM »
wow thanks for the great info Odbod. Will have to see what i can source locally, atleast now i know what to order :)
marko
Single Row Chain
« Reply #36 on: February 09, 2009, 08:11:51 AM »
one thing to keep in mind (after speaking with MM) is that the chain is not going to cause a problem - i.e. it will not break, however, MM told me that once my motor is installed with the STC conversion, I WILL have to keep a keen eye on the chain tensioner (checking it at least every 6 months) - making sure that the tension is optimal at all times.
appeareantly the chain will last fine providing there is no slack...
I'm getting my MM motor end of this month, & will let you guys know how it works out.
« Last Edit: February 17, 2009, 06:29:44 AM by marko »
JP 91iS
Single Row Chain
« Reply #37 on: February 09, 2009, 02:52:52 PM »
Quote from: marko;66174
I'm getting my MM motor end of this month, & will let you guys knwo how it works out.
OT: Marko: Maybe you covered this elsewhere, but what are you going to do with your DASC?
-JP
marko
Single Row Chain
« Reply #38 on: February 10, 2009, 06:56:47 AM »
keeping it... DASC is going on the MM motor.
somewhat like in the thread below, but with MUCH less boost :D
http://www.318ti.org/forum/showthread.php?t=24635
Quote from: JP 91iS;66189
JP 91iS
Single Row Chain
« Reply #39 on: February 10, 2009, 07:22:47 AM »
Quote from: marko;66249
somewhat like in the thread below, but with MUCH less boost:D
nice! I'm jealous - but you should consider putting the setup into an E30 :cool:.
-JP
odbod
Single Row Chain
« Reply #40 on: February 10, 2009, 07:32:43 AM »
there's a DASC kit on sale in te UK for £600 at the moment on http://www.pistonheads.com/sales/886244.htm
I've not got enough money to buy sadly, too much spent on a 2.0l build
marko
Single Row Chain
« Reply #41 on: February 10, 2009, 07:59:16 AM »
get it man... that is a steal! I paid 3.3K for mine...
it will enhance any other additional work on your motor... not too much boost & so you do not need any crazy mods like for a turbo (i.e. designed to work with stock internals - stock ecu, etc).
Quote from: odbod;66252
« Last Edit: February 22, 2009, 09:29:12 AM by marko »
marko
Single Row Chain
« Reply #42 on: February 10, 2009, 08:00:16 AM »
yes, I should - you are right. :)
I absolutelly love E30s.. they have a special place in my heart, just like the 87-92 Gti 16Vs.
Quote from: JP 91iS;66251
« Last Edit: February 17, 2009, 06:28:58 AM by marko »
max123
Single Row Chain
« Reply #43 on: February 16, 2009, 07:10:24 PM »
The early mercedes 2.3-16v motors used a single row timing chain, but they upgraded to the dual in the later model because of durability issues.  I don't see a snapped timing chain thread in this forum, so maybe BMW got it right from the factory
marko
Single Row Chain
« Reply #44 on: February 20, 2009, 08:47:41 AM »
as promised - here are the pix of my upcoming MM motor with a single timing chain conversion... the guys from Metric have been kind enough to send me some pix from the build, to salivate over.
more pix of the entire thing here:
http://www.318ti.org/forum/showthread.php?t=25646
« Last Edit: February 22, 2009, 09:29:43 AM by marko »
