Author Topic: Single Row Chain  (Read 13372 times)
m44power
Single Row Chain
« on: September 16, 2008, 02:50:12 PM »
Single Row Chain anyone knows something about this modification ? maybe a chain of M30 can do the job ? or from a new N43 ? does it worth the trouble  ?? any opinions?
halcron
Single Row Chain
« Reply #1 on: September 17, 2008, 02:45:38 AM »
I do know MM has single row chains and sprockets for M42 but no sure how much it cost though. IMHO, single chain will reduce parasitic drag a little and should able to increase HP a little.
m44power
Single Row Chain
« Reply #2 on: September 17, 2008, 10:50:45 AM »
MM uses original machined sprockets and some single chain i can see the benefits of this mod but it worth ?
christophbmw
Single Row Chain
« Reply #3 on: September 17, 2008, 10:55:35 PM »
im sure its not more than 1hp, i think MM does it to extend the life for high revving engines.
m44power
Single Row Chain
« Reply #4 on: September 19, 2008, 02:02:56 PM »
and what about parasitic drag ?
Massimo
Single Row Chain
« Reply #5 on: September 23, 2008, 05:17:22 PM »
Reduces rotating mass more rpm
m44power
Single Row Chain
« Reply #6 on: September 24, 2008, 11:16:53 AM »
im think its verry easy conversion some machining and N4x chain
GrindCulture
Single Row Chain
« Reply #7 on: September 24, 2008, 03:04:11 PM »
I'd like to see someone attempt it and see if it's worth it. Could be another little job to add to my "to do" list. I'd give it a go myself, but if I balls it up then I'll be walking to work...
E30 M42 Touring rightness!
Massimo
Single Row Chain
« Reply #8 on: September 24, 2008, 05:52:59 PM »
I don't think the performance gain is worth the risk a of single chain, the twin chain is alot stronger and a safe gard if one breaks.
nuvolarossa
Single Row Chain
« Reply #9 on: September 25, 2008, 06:39:49 AM »
there are a lot of things that can do to this engine before than that... :D
e30guydownunder
Single Row Chain
« Reply #10 on: September 25, 2008, 11:13:03 PM »
Quote from: Massimo;57305
if you think about it...the fact that BMW have gone to the effort of developing a single row chain for the N4x series engine (we'll assume its safe) should be saying something.
And given it is a newer design, if it does fit???? it will also be most likely somewhat stronger than even our double row timing chains.
Don't forget that BMW was quite happy running the single row on the m30's and they even ran a single row chain on the euro version of the m88/3 in      m635CSi's ;)
m44power
Single Row Chain
« Reply #11 on: September 28, 2008, 09:49:15 AM »
Quote from: e30guydownunder;57391
+1 are m635csi a single row chain ?
m44power
m44power
Single Row Chain
« Reply #13 on: September 28, 2008, 09:55:10 AM »
Quote from: nuvolarossa;57341
yes but this one it cost nothing...
nuvolarossa
Single Row Chain
« Reply #14 on: September 28, 2008, 11:29:27 AM »
391g for the N42 chain and 894g for the M44 ;) that's some nice weight loss!
M43 (8v) sprocket is for single chain, do you think that two of the can fit on our engines with N42 chain?
« Last Edit: September 28, 2008, 11:43:36 AM by nuvolarossa »
