Author Topic: Wifeys new E30.  (Read 4482 times)
White325is
Wifeys new E30.
« on: May 14, 2008, 07:29:38 AM »
Well I thought I would post some photos of the e30 I bought for my wife.
There not that great and the car DOES need some work.
It will all be taken care of before time.
She has some big plans for this car when winter comes around.
Well on to the shitty photos.
Cobra Jet
Wifeys new E30.
« Reply #1 on: May 14, 2008, 11:19:42 AM »
the paint looks good on it in the pics
is it sitting "high" or just due to non-level parking lot surface?
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
White325is
Wifeys new E30.
« Reply #2 on: May 14, 2008, 01:32:45 PM »
its sitting high. less weight due to no sunroof.
I just got dont doing all of the vacume lines and cleaning out the TB and ICV.
Idles so much better now.
needs the valves adjusted and the timing chain stuff done.
I notice after I got done doing all this work and letting the car run for a while that it was building a lof of pressure in the cooling system and pushing coolant out of the resivor.
I took the cap off and the bleeder screw and let it run for a while and it just pushed coolant out again.
Im thinking that the car might have a bad HG.
any ideas??
Kilawin
Wifeys new E30.
« Reply #3 on: May 14, 2008, 02:56:01 PM »
Slick top FTW.
Wifeys new E30.
« Reply #4 on: May 14, 2008, 06:06:30 PM »
Quote from: White325is;49330
any ideas??
No valves to adjust on this motor! Is it ticking loudly?
White325is
Wifeys new E30.
« Reply #5 on: May 14, 2008, 08:49:28 PM »
Yeah like a diesel ..lol
Im thinking its the guides on the timing??
mach schnell
  • does it fast
Wifeys new E30.
« Reply #6 on: May 14, 2008, 08:59:16 PM »
Looks nice!  Red is awesome.  And no sunroof, cool.
Wifeys new E30.
« Reply #7 on: May 14, 2008, 09:45:57 PM »
Quote from: White325is;49364
You can start with the timing chain tensioner, and some heavier oil...like 15w40.
If it STILL sounds like a diesel you will probably have to open her up to inspect guides and cam sprockets.
White325is
Wifeys new E30.
« Reply #8 on: May 15, 2008, 06:49:05 AM »
Quote from: dude8383;49369
Well right now I plan to drop the 550 on all new parts and go from there.
Right now I noticed it had some serious are bubbles in the coolant.
If something is wrong with the motor then the wife will get the M50 in my car and Im going to build a turbo M42. or do a supercharger.
Wifeys new E30.
« Reply #9 on: May 15, 2008, 09:10:51 PM »
Quote from: White325is;49386
oh you da man. :D
White325is
Wifeys new E30.
« Reply #10 on: May 16, 2008, 09:30:49 AM »
ok well I did a comp test and it was around 150 across the board.
I did a leak down test also and everything was good.
So I figure it has a bad T stat.
White325is
Wifeys new E30.
« Reply #11 on: May 20, 2008, 04:24:36 PM »
all the timing parts showed up today.
She is very happy that we will be getting the car fixed.
lets just hope it all works out for the best.. :o
