Author Topic: My temp Gauge is Alive  (Read 5576 times)
Crunk3
« Reply #1 on: March 03, 2008, 07:20:02 PM »
he's just dancing to the music!!
mine does the same thing some times.. think its just when its low on coolant. maybe you need to bleed the system?
Crunk3
« Reply #2 on: March 03, 2008, 07:21:07 PM »
I did in the Summer
quinn11m20
temperature gauge dance
« Reply #3 on: March 04, 2008, 11:06:52 AM »
When your gauge is moving like that you need to check your ground wires. there is one at the battery and one at the engine just under your headers. i would suggest those first. once you have replaced them if it still does it you have to replace the little memory/computer board behind your service interval light on your gauge panel. Following Me? You can find the memory board at bavarian autosport. http://www.bavauto.com . They sell it for $135.  hopefully that solves your problem. It did mine.
sheepdog
  • Site Admin
« Reply #4 on: March 04, 2008, 11:15:05 AM »
Quote from: quinn11m20;44101
I have also heard to try cleaning the contacts behind the cluster.
And yes, Mine does it too.
oldtimer
« Reply #5 on: March 05, 2008, 05:50:03 AM »
I found the nut that holds the gauge to the cluster was loose.  so before you go buy a new guage and or start to disassembling things I recommend taking th ecluster and look at that nut.
Choking Hazard
« Reply #6 on: March 05, 2008, 09:31:17 PM »
Quote from: oldtimer;44142
exactly.
[SIGPIC][/SIGPIC]-Scott
Spec 2
    • http://www.pnwriders.com
« Reply #7 on: April 11, 2008, 03:59:35 PM »
I'm doing that this weekend because I'm sick of mine dancing about.  Informative info.  Thanks, all.
batsbats
« Reply #8 on: April 11, 2008, 09:51:57 PM »
Hah, I thought mine was the only one that danced..
Sidebar question, what's normal operating temperature of a M42?  Mine hovers a mm to the right of the middle dash.  Noticed yours was to the left of it.
SnPaC
« Reply #9 on: June 26, 2008, 06:15:05 PM »
Quote from: batsbats;46835
Mine also...
bmw327
« Reply #10 on: July 02, 2008, 08:36:32 PM »
Dancing gauge here too, only mine dances to the right, which was most alarming the first time it did so...a sharp rap on the dash above the gauge calms things, so I suspect a loose nut / connection.  Normal reading on the gauge is dead center to just a hair to the left.
1991 318i
1938 327 Cabriolet (project)
SnPaC
« Reply #11 on: July 03, 2008, 09:05:44 AM »
Quote from: bmw327;52493
Same here
Sam Cogley
« Reply #12 on: July 03, 2008, 04:13:28 PM »
When mine is calm, it's always dead center or a bit to the right.  Nowhere close to red, though.
BMWManiac
« Reply #13 on: July 17, 2008, 12:28:04 PM »
Mine just started dancing and even is about halfway to the 3/4 mark for too hot......makes me think about re bleeding it because I've never had a problem in the past month....is it just the guage or should I be worried?
2006 Interlagos Blue Z4M Coupe
Premium pack, navigation, heated seats
1997 Artic Silver M3
Built motor + SC62 + TRM tune
545rwhp/520rwtq
Gray S.
« Reply #14 on: July 17, 2008, 08:42:00 PM »
Quote from: BMWManiac;53400
Mine used to be like that also, then I cleaned off the ground nut that holds the gauge in the cluster.  Now mine sits right on the middle line or like half a needle width to the right in 100 degree NC weather.
