Author Topic: The S42 Race Engine !!!!  (Read 163152 times)
RouteZeroDesign
« Reply #45 on: March 26, 2008, 09:38:39 AM »
Quote from: swiss318is;45444
i know!!!since i know that a s42 engine exists i found about 5 pics in the internet and now i have a looooooooooot more :-) thanks for the beer... where do you live... :-)
I live in Ireland, where are you from?....only joking, you make it very obvious:D
Whenever you get a chance to take photos of the engine parts it would be brilliant, but theres no huge rush.
Question: would it be possible for you to bring a ruler along with you when your taking pictures? and place it beside the parts when your taking the photos?
That way we would be able to get a rough idea of the sizing of some of the parts...obviously it wouldnt be very accurate but it might give us a rough idea.
RouteZeroDesign
« Reply #46 on: March 26, 2008, 10:01:31 AM »
Okay, i think i have spotted the Dry sump tank. It is located behind the drivers side headlight, just to the right of the intake snorkel.
You can see the the tank in the bottom right corner of this picture.
The hose with the Aeroquip fitting going into the tank is the input hose. The oil then goes into the tank and is sucked out the bottom by the second stage of the pump.
You can see in the bottom right of this picture the material sticking out the top of the filler neck. This material is used to seperate out any air from the oil (it is generally used in catch cans), it also acts as a dampening material for the tank.
Not that anyone asked the question but im just thinking out loud, trying to analyze the pictures :)
Bttw Swiss, the adjustable blade antiroll bars are incredible, and the fact that they can be adjusted from the drivers seat just astounds me!
« Reply #47 on: March 26, 2008, 10:53:19 AM »
i am not sur if thats really the main catch tank, it seems a bit too small for me. usually there are build for 5-6liters of oil. it could be that this is the first tank, then there is somewhere an other one.
like the fuel system.
the big fueltank-pump-catchtank-pump-engine
oilsystem (perhaps!!)
oilpan-pump-small tank-(pump)-big tank-engine...
the next time i will ask and then take a pic..
RouteZeroDesign
« Reply #48 on: March 26, 2008, 11:20:00 AM »
I was thinking that it might extend underneath that panel but that might place it very close to the ground and also in a very dangerous position in the case of an accident.
Oil all over the track=not very good.
The tank i pointed out might just be a catch can for the main oil tank. Almost like an atmospheric breather (hense the material inside).
The only other places that it could be are under the airbox or in the boot where the battery originally goes.
Infact the battery box seems to make sense as there are some AN lines running towards that area of the boot in your pictures of the rear anti-roll bars...and also placing it there would be better for weight distribution.
And if i remember correctly, the FIA rules about dry sump tanks state that they have to be in a seperate compartment to the driver or else surrounded by an enclosure....hmmm
If you wouldnt mind asking the next time that would be cool :)
« Reply #49 on: April 04, 2008, 04:06:51 AM »
i am on the way to the s42 to take pics again ... ;-)     i am sooooo horny....!!!
romkasponka
« Reply #50 on: April 04, 2008, 12:28:06 PM »
do not forget chain tensioner :P
E30 318is M42
E36 318is M44
« Reply #51 on: April 04, 2008, 01:14:22 PM »
Quote from: romkasponka;46132
the chain tensioner is on a s14 dtm engine.... not on this s42.. sorry
romkasponka
« Reply #52 on: April 04, 2008, 05:24:22 PM »
this S42 with stock tensioner?
E30 318is M42
E36 318is M44
christophbmw
« Reply #53 on: April 04, 2008, 09:42:20 PM »
...just put down the latest playboy to look at these pics. WOW!
« Reply #54 on: April 07, 2008, 09:52:30 AM »
Quote from: RouteZeroDesign;45536
the small tank is for ventilation only.. the main drysump tank is near the gearbox..
« Reply #55 on: April 07, 2008, 09:56:32 AM »
one of the damaged head for the s42
it only seems to be almost the same as the m42 but this one is MUUUUCH MORE LIGHTER !!!!!
« Reply #56 on: April 07, 2008, 09:59:00 AM »
thats the reason why the head is useless at the moment, its freshly welded...
« Last Edit: April 07, 2008, 10:22:14 AM by swiss318is »
« Reply #57 on: April 07, 2008, 09:59:59 AM »
« Reply #58 on: April 07, 2008, 10:00:40 AM »
intake...
« Reply #59 on: April 07, 2008, 10:01:10 AM »
outlet...
