I <3 this thread
I think i can delete a few of these questions off the list
3. material of the valve inserts and the valves?
Beryllium for the Valve inserts and Titanium for the Valves
6. why are there caps between valve guides and head?
Titanium valves need extra cooling because titanium has a lower melting point than steel. Therefore Beryllium valve inserts are used (Beryllium 25 intake, Beryllium 3 for the exhaust) Two different types of Beryllium are used because the exhaust valve seat needs extra cooling, therefore it uses a higher percentage of Beryllium in the exhaust valve than it does in the intake.
Would you be able to verify the percentages?
The most common ratio ive seen is 98% Cu Intake, 97% Cu Exhaust)
7. cylinder head cover ventilation..
The s42 doesnt have a valve cover breather. It uses a dry sump pump which creates a vacuum in the crank case( Another reason why it makes so much power per litre).
Dry sump systems like that dont need a breather because any oil vapour is sucked down into the dry sump pump and on into the oil tank. The Tank itself has a breather tank which is used to seperate out any air from the oil.
Il post up my wish list later on, im heading out now
