m42 Vs m44 injectors does anyone knows something about it ? characteristics and some more info im curently running m44 wiring and ECU with M42 injectors i think there is a little problem
Hi, all that I can say now is that they have same impedance and same flow, but the diameter is different: the M44's are bigger diameter, and they are shorter to than a m42 injector. Do you have another manifold, or adapters, because the M42 injectors don't fit with m42 manifold and vice-versa.. bye
