Author Topic: M42 Vs M44 injectors  (Read 13303 times)
m44power
« Reply #15 on: June 09, 2007, 07:31:32 AM »
i post some pictures of m42 Euro Injectors (left) and some m43 injector (right) m44 injector is the same but with different collor stripe (i think orange) and different capacity as you can see m44 injector have air tube but all injectors m42 , m43 and m44 is 4 pintle spray
m44power
« Reply #16 on: June 09, 2007, 07:37:26 AM »
Quote from: nuvolarossa;27233
I don't know about disa, but what tubes are you talking about? M42 inj aren't air shrouded... so what tubes?
intake tubes the whole intake is a little bigger.  Before i running plastic DISA i broke them into peaces 6 times :) and all the plastic pieces stucks in my sparks :) each time cost me a brandnew DISA and 4 spark plugs :) now im running metal DISA from m42 with a capasitor 62ohms in the valve cable it works perfect!
Impedance and flow I'm sure at 100%.. can't remember the exact numbers because I'm not at home now, but they are exactly same impedance and same flow. I had them connected and the m44 ecu gave not a error;)
soo... the problem is my injectors condition
« Last Edit: June 09, 2007, 07:56:19 AM by m44power »
nobrakese36
« Reply #17 on: June 14, 2007, 10:29:35 PM »
You are not having problems with m42 injectors with the m42 manifold in your m44! do you have a picture of your manifold set up,thanks.
m44power
« Reply #18 on: June 15, 2007, 02:15:20 AM »
Quote from: nobrakese36;27751
i dont know why but  my engine runs lean my lamda value is more than 1 i dont have any pictures of my manifold but im gone take some shots for you soon
