Author Topic: Hi there  (Read 95504 times)
e36mike
Hi there
« Reply #150 on: September 06, 2008, 03:10:13 AM »
im also not going to do anything to my internals
just gonna make up manifold extra injectors and smt6
check out my in car setup
e36mike
Hi there
« Reply #151 on: September 06, 2008, 03:15:02 AM »
e36mike
Hi there
« Reply #152 on: September 06, 2008, 03:20:09 AM »
e36mike
Hi there
« Reply #153 on: September 06, 2008, 03:25:26 AM »
halcron
Hi there
« Reply #155 on: September 06, 2008, 09:37:24 PM »
Quote from: ludiagsm;56097
it looks great wish you luck with porsche projects :)
pp: on my 316 m40 i use stock engine ,stock rods ,pistons valves and cam ,bearings just turbocharger four extrainjectors map sensor smt6 ,aluminium flywheel with 240mm sachs sport clutch not keramic just kevlar , i use original gearbox  diff from e36 325 with internels from e34 with 3,46 ratio and that is all :)
How about your M42. What internals are you using to be able to run at 2 bars?
Thanks!
ludiagsm
Hi there
« Reply #156 on: September 07, 2008, 12:46:34 AM »
Quote from: halcron;56171
Thanks!
you must read all pages behind there is a info ;)
ludiagsm
Hi there
« Reply #157 on: September 07, 2008, 12:56:38 AM »
here is pictures to my 316 m40 turbo it is not like from magazine but all things works fine :) :
« Last Edit: January 05, 2009, 05:18:23 PM by ludiagsm »
ludiagsm
Hi there
« Reply #158 on: September 07, 2008, 01:23:40 AM »
Quote from: e36mike;56133
http://img296.imageshack.us/my.php?image=image019qa1.jpg
http://img296.imageshack.us/my.php?image=image020rm2.jpg
http://img165.imageshack.us/my.php?image=bmws44b20touringcarengijw2.jpg
hey mike i think it will be better if you made your own thread with info and pics from your projekt because mine is too big ;)
« Last Edit: September 07, 2008, 07:59:18 AM by ludiagsm »
halcron
Hi there
« Reply #159 on: September 07, 2008, 10:15:48 AM »
Quote from: ludiagsm;56189
Oh sorry, I miss out your page 2. Found the info on pg2 of the thread. I understand you are using Wossner pistons and Honda conrod (made by Eagle). Am I right?
Btw, I couldn't find any info regarding the crankshaft? Are you using stock crank or another crank?
Thanks!
e36mike
Hi there
« Reply #160 on: September 07, 2008, 10:30:00 AM »
ok i will but you must check on it so you can help me if i make mistake
also tell me are you using same fuel supply for the extra injectors
why is there no vacuum pipe on old fuel pressure regulator or is it running on the extra injectors
ludiagsm
Hi there
« Reply #161 on: September 07, 2008, 01:30:36 PM »
Quote from: halcron;56203
Thanks!
yes wossner pistons made for c20led and honda konrods made by eagle , the krank for now is stock with 81mm stroke
ludiagsm
Hi there
« Reply #162 on: September 07, 2008, 06:04:52 PM »
Quote from: e36mike;56205
ok i will help you
yes i use same fuel supply but dont use original fuеl pressure regulators  i use just one exturnal. The old regulator does't work i use him only for cap.
e36mike
Hi there
« Reply #163 on: September 08, 2008, 12:16:28 AM »
great thank you
do you use standard pump?
does fuel line supply both fuel runners or seperate one for each runner
vagrant_mugen
Hi there
« Reply #164 on: September 08, 2008, 01:03:05 AM »
Quote from: nuvolarossa;28279
I've made some researches:
-wiseco pistons for C20LET make a CR of 8,5:1, forged.
 Are these Opel pistons drop in for the 1.8L m42 motor??
i found these: http://www.importperformanceparts.net/imports/wisecopistons_opel.html
 the same distributor carries these rods for the m42:
http://www.importperformanceparts.net/imports/eaglehrods_bmw.html
very good prices and they are the correct length, not like the honda rods.
just want to make sure they are the same as the 1.8L m42 pistons????
« Last Edit: September 08, 2008, 01:08:19 AM by vagrant_mugen »
