Author Topic: Mustang Injectors in an M42 engine  (Read 261509 times)
Choking Hazard
« Reply #195 on: March 04, 2010, 08:12:22 PM »
She's a runnin!
I think it was that wire dangling from the fuel rail.  The one that had a conveniently corresponding socket on the wiring harness for the plug at the end.  Maybe.   Well, Ok.  Probably.
Thanks fer the help kids!
[SIGPIC][/SIGPIC]-Scott
cristimm
« Reply #196 on: March 15, 2010, 01:12:20 PM »
Quote from: colin86325;66430
Some of the later E36 M42 injectors used a sort of air injection into the fuel injectors in an effort to reduce emissions:
http://www.motortraders.net.au/groups/group.asp?group=1&menu=88
This air injection is just stupid and prone to fail.
cristimm
« Reply #197 on: March 17, 2010, 01:01:46 PM »
I have a quick question regarding injectors:
Currently I'm cleaning my spares which I won't use for a while. After cleaning should I lubricate them internaly for storage? I don't think it's ok to stay for a long time with cleaning liquid inside them.
daqqer
« Reply #198 on: March 27, 2010, 03:23:27 PM »
Quote from: daqqer;85269
My 318iS (chip, throttlebody mod, intake mod, intake pulse chambers, cold air intake, richer air-fuel mixture, no fuel pressure regulator tho, exhaust is without any cat). Engine will be stock internals. And only for Sunday/track use. What would be the best injectors performancewise for me ? I dont care about fuel consumption, and white/black smoke or nasty smells. :D Ah also, im probably going on MegaSquirt some day also.
Bosch 0280155702 #22 or Bosch 0280150947 #24.5 or something else ?
I can put better fuel pump and regulator if you think thatll help anything. :P
Opinions please. ˇˇ
Im soon getting to that phase and need to decide what injectors to use.
Thanks.
Ken
autox320
  • -Receive: 2
« Reply #199 on: April 01, 2010, 03:22:44 AM »
After a previous post I realized this wasn't added.
Found 19# yellows here at five o motorsport
http://www.youtube.com/watch?v=VfynoxL2RZI
flyinglizard
« Reply #200 on: April 01, 2010, 06:28:55 AM »
280 155 715 fit and work well. @ 22# around 42psi. (blue)
   Common 4 hole injector.  My source is back inhere somehwere.  80$ for 4 nice ones.
   MM
Mike and Michael Ogren/Protech Racing Services, mogren@tampabay.rr.com
  data analysis, driver coaching, race car development. FWDracingguide.com  . Chumpcar rental
 20 years of renting race cars
  • -Receive: 5
« Reply #201 on: April 01, 2010, 08:35:51 AM »
Quote from: 4banger;88795
how many lb/hr do the yellow ford 302 injectors flow?
These should be 19# injectors. Depending on model year they'll either have EV1 or EV6 design. I think ford kept using the 302 in the explorer late into the 90s.
Quote from: autox320;90311
These things are dime a dozen in the junkyards. Seriously, every V8 Ford from the late 90s has these. Buy them used at the JY and have them cleaned or clean them yourself if you really care.
http://fordfuelinjection.com/?p=82
Quote from: flyinglizard;90314
   MM
These are #24 injectors from a 24 valve Ford taurus from the late 90s.
« Last Edit: April 01, 2010, 08:38:55 AM by tjts1 »
ryanjv
« Reply #202 on: April 19, 2010, 09:21:52 AM »
is there anyway to check whether its 1pintle or 4 on the witchhunter site or the table site ?
i've found injectors that are 0 280 150 943
http://users.erols.com/srweiss/tableifc.htm#BOSCH
Warsteiner
  • -Receive: 21
« Reply #203 on: April 19, 2010, 10:12:45 AM »
Why would you want to change injectors for 5+cc's?  I just had 2 sets of stock injectors tested and cleaned.  Both sets ran 204cc's.  Go have your inj's cleaned!
Mine are for sale. PM me if interested.
~Ralph
Redpolack
« Reply #204 on: April 20, 2010, 04:14:59 PM »
what is the part number for volvo injectors?
« Reply #205 on: April 21, 2010, 01:25:10 PM »
I just bought a set of injectors on ebay, pictured below.
The stockers are these.  So there's a small increase in fuel flow with the "new" ones (6.25% more).  tjts1, you said you were running the 155 712's?  Those look to be LOW impedance units (2.1 Ohm)...is that right?
I will be interested to see if this cleans up my idle & evens out my power band like so many others have reported.  That sure would be nice!
flyinglizard
« Reply #206 on: April 21, 2010, 08:34:00 PM »
The new injectors are 4 hole and newer. The idle can improve along with fuel use.  The DME seems to adjust to the flow rate just fine.
 I use the 280 155, 715.  for a lot of the Bosch style cars,BMW, Volvo, Vette, Ford crap etc.
  HTH, MM
« Reply #207 on: April 21, 2010, 10:33:36 PM »
OK, is there a final, DEFINITIVE answer about needing to modify anything to fit 155 injectors?
It seems that, from posts here, that washers & filing are not needed...they fit fine with everything stock.  Is this true?  The drawing comparing dimensions indicates that the EV6 & EV1 units indicates that the EV6 ones are ~3mm shorter.  Has anyone checked to see if the bottom of the injectors are fully engaged in the lower manifold when installed?
If they ARE too short, the only proper course of action would seem to be filing ~3mm off of the rail mounting points (easy to undo with washers at least).
flyinglizard
« Reply #208 on: April 22, 2010, 08:31:17 AM »
Usually, you have to remove the old injectors , one by one as they are stuck in pretty hard, the seals are beat, etc.
 The 715s are a little shorter. Placing all 4 on the rail, locking the retainers, ATF on the new seals,  slide the ass. in to the intake.  The seals fit in the  injector cylinder a little higher than the orig. but the seals are not slammed against the bottom. I have not had any issues or do overs.  WFM. <
dinu.negrean
« Reply #209 on: April 23, 2010, 05:19:53 PM »
I have done it and you do not need any washers or filing, they sit and worked fine for me without any other modifications.
M42 covered in Kaschmirbeige Metallic
