Author Topic: Mustang Injectors in an M42 engine  (Read 261616 times)
Rogan
    • http://www.540autosport.com
« Reply #90 on: August 16, 2008, 11:17:19 AM »
found a couple of pics from when I was 'modding' the WRX injectors..
left is "modded" one at 800cc, right one is stock 420cc
\'02 WRX - built 2.5L  ||  Precision GT32  ||  Tial BOV/EWG  ||  Arias 9.5:1  ||  Eagle Cromoly H-beam conrods  ||  ARP  ||  Cometic  ||  417awhp @ 19psi
\'85 325e coupe - M42 swap, eta rear = 38mpg!
ClodKing
« Reply #91 on: August 16, 2008, 12:11:30 PM »
Will those fit in an M42??
Asserti
« Reply #92 on: August 20, 2008, 01:04:24 PM »
http://cgi.ebay.com/ebaymotors/FUEL-INJECTOR-BOSCH-0-280-150-927_W0QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247QQcategoryZ33554QQihZ009QQitemZ190100407058QQrdZ1QQsspagenameZWD1V
would these injectors fit, without the washers?
These are the specs:
0-280-150-927   21.8lbs   229.1cc
From this site:
http://users.erols.com/srweiss/tableifc.htm#BOSCH
And after reading this thread twice, what are the improvements? smoother idle? But perhaps I can get result with cleaning my injectors?
[/URL]
JP 91iS
« Reply #93 on: September 16, 2008, 01:29:46 PM »
I was doing some research on the Bosch 0280-150-556 Injectors and I was trying to find the Ford part number for it. (the reason being that all the auto parts stores I went to couldn't find the injectors from the bosch number) Here's what I found, mostly from this one website:
Final Edit:  After looking around on many different websites and only getting conflicting answers I removed the (mis)-information I had posted here.  Instead here is a list of the websites I was using as a resource.
http://www.fuelinjector.citymaker.com/page/page/4511825.htm
-A list of Bosch injectors available from Motor Man Fuel Injection Supply
http://www.fuelinjector.citymaker.com/page/page/5516057.htm
-A list of injectors by Motorcraft part number (Ford) available from Motor Man
http://www.fuelinjector.citymaker.com/catalog/item/4494564/4532416.htm
-Motor Man information on the 0-280-150-556 Bosch injector. They list alternate Bosch injector numbers that have the same Ohms, flow rate, and casting numbers. Under that they list the "engineering number" which is the Ford part number.
http://www.motorcraft.com/catalog.do
-Find the Motorcraft part number by vehicle search
http://www.rockauto.com/catalog/raframecatalog.php
-Find part numbers and applicable years
http://www.boschautoparts.com/Resources/VehiclePartFinder/
-Find Bosch part numbers by vehicle search
« Last Edit: September 17, 2008, 10:51:58 AM by JP 91iS »
-JP
Project M42: generating funds
  • -Receive: 5
« Reply #94 on: September 16, 2008, 02:21:28 PM »
Quote from: JP 91iS;56806
They list alternate Bosch Injector numbers that have the same Ohms, flow rate, and casting numbers.  Under that they list the "engineering number" which is the Ford Part number.
Be careful. Ford didn't use any 4 hole injectors prior to 1996. Mercedes was the first company to use them in 1992 on the 3.2 liter inline 6.
dbgrubbs
« Reply #95 on: September 17, 2008, 06:40:21 AM »
JP 91iS
« Reply #96 on: September 17, 2008, 10:37:29 AM »
Quote from: dbgrubbs;56850
I've got 4 556's for sale on ebay right now if anyone is interested.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&sspagename=STRK%3AMESELX%3AIT&viewitem=&item=140267857727
Bought and Paid.  Thank you.
-JP
jrobie79
« Reply #97 on: September 22, 2008, 02:33:36 PM »
so after all the discussion --- which mustang injectors should i put on my stock m42?
I have seen a ton of part numbers thrown around on this thread, and still cant figure out which car to pull these from. What specific year mustang will these come off and whats the best part number to use w/o having to mod anything with washers or the like. thanks
« Last Edit: September 28, 2008, 08:05:13 PM by jrobie79 »
jrobie79
« Reply #98 on: September 28, 2008, 08:04:59 PM »
Quote from: jrobie79;57177
bump
  • -Receive: 5
« Reply #99 on: September 28, 2008, 09:30:22 PM »
Read page 3.
dbgrubbs
« Reply #100 on: September 29, 2008, 06:36:22 AM »
The injectors I used were from an '04 Mustang GT with Bosch # 1 280 150 556. These are a direct fit and depending on which list you look at, may be either a slight upgrade in flow or the exact same as stock. You may also want to look for 1 280 150 943 (I have 4 of these as spares if anyone is interested). These are either the same flow as stock or slightly less and quite a bit more plentiful. Again due to which injector list you believe. Both of these do NOT need washers to fit correctly.
« Last Edit: September 29, 2008, 06:38:29 AM by dbgrubbs »
  • -Receive: 5
« Reply #101 on: October 05, 2008, 01:10:05 PM »
:p
Kingsly
« Reply #102 on: November 07, 2008, 03:32:51 PM »
Just got 8 #0 280 155 700's off ebay. How do you guys recommend I clean them? I want to make sure they're good before installing!
Also, once I'm done I'll have four left over, if anyone's interested. :)
keflaman
  • -Receive: 35
Still Got 'Em?
« Reply #103 on: November 15, 2008, 01:39:18 AM »
Quote from: Kingsly;60164
I'm interested. Will PM you shortly.
KyleTaylor
« Reply #104 on: November 15, 2008, 11:43:21 PM »
Are you using "used" injectors or rebuilt, or "sonic cleaned" or what for your car, tjts1?
