The picture is a bit blurry but you can see the 1/2" washer at the bottom of the injector. Oh and 190 miles at 1/2 tank so far.
Justin,
Just curious...  is it really "safe" to run the vehicle w/ your "washer mod" on the injectors?  I would be concerned about a fuel leak if the injector were to shift or not be 100% sealed properly due to having to use a metal washer.
That solid orange, skinny Mustang injector is the newer style "mod-motor" injector as used on the 96+ SOHC & DOHC Mustangs (and other Fords).
The other Mustang injector, which has the silver body & yellow top is the 5.0 19lb injector that was used on nearly all 1986-1995 Mustang 5.0's (and other 5.0 Ford products, including the Crown Vics, Lincolns, Broncos, F-Series trucks, etc).
You cannot safely use the newer style solid yellow injector in place of the older style injector due to the differences in height and sealing characteristics of the O-rings & fuel rail assemblies - mainly because of possible fuel leaks.  Granted we are talking using these parts in BMW's so some of the above is null & void as it applies to Fords, but if it were me, I would surely use the same type of injector as a replacement (exterior characteristics/dimensions - height/o-rings, etc) rather than trying to make a different type "fit".  Again, I'm not saying what you did is 100% incorrect, as it does seem to work, however, IMO it's not the best solution and just does not seem as safe w/ using a washer to hold the injector into the fuel rail & intake.
