It fit the rack fine where the 2 6mm bolts hold it to the rack, but it was bent a bit & had a few restrictions in the line where it had been dinged. I bought the rack from a local who had pulled it with little regard for storing it. So when I got it, the banjo bolt was off that end & I didn't think much about it. When I was trying to get the banjo bolt in last nite, it wouldn't line up right & that end of the cooler has a big U bend sorta, then a tiny bend near the fitting. I got close, but decided to ditch it. I still have the small cooling coil on the other line, so I'm not worried about cooling. I had the cooler installed on the rack before I installed the rack, the steering shaft installed to the coupler & had the rack bolted in with washers on top. It was then I started the fight of Bend this end near this U bend just 5 degrees this way & 3 degrees that way. It was off by a minor amount. Then I looked, thought about how it blocks acccess to M42 upper oil pan bolts, thought about the dings that almost crimped the line to 1/2 it's size as restrictions in a few spots. Decided right then, too much fight, it wasn't in good shape to start with, it's also so close to the subframe, I was thinking this is possible rub or vibration issue if motor mounts get weak or something.
Thanks for the offer on the line, if you decide to not use it can you post a pic ? I'll gladly pay if this is a new part or pay shipping if it's used & I can use it.
