With the fan center section out I wanted to clean it up and have a closer look at that seized fan...
There are two different fans, one for a/c cars and those without. The shorter one is for a/c:
I had a spare that came with the car. Obviously the PO had ordered the wrong one: Pay attention to the details
on realoem to not screw up
your order... Same goes for the rad unit...
I point out the plastic inlet/outlet piping on the rad for the same reason...
To get the fan out, pop the clip that holds it in place with a flathead screwdriver from the bottom and disconnect the two wires as shown..
Clip and wires...
bottom...
open...
With the fan out I really wanted to get my hands on that rad..
Three screws and it slides right out.... Oh no... Not so easy..
You have to get this POS out of the way first... Just to p*ss you
off of course...
Tried the lazy way...Almost...but not quite...
out...
With that out of the way NOW I slid out the rad...
Much to my surprise it seemed to be in really good shape. So of course I ordered a new one.
For those of you scratching your heads, look up Murphy's Law in wikipedia...
Next up I cleaned what was left of the foam sealer (shown here)..
It crumbled into dust. New one ordered.
I also completely washed the unit, inside and out. Well within my abilities methinks...
With that done my attention turned back to the seized fan:
That pic was taken after grinding all the surface rust and shite off of it... I air blew it cleaned and tried to rotate the shaft..
No luck...So I got angry and tried again...
Almost went cardiac and again no luck...
Gave it to my son for a go...Here is a pic after he got it free..
Jerk...
