Poll
What color should I paint this thing? Non-Oem not really being considered....
Original brillantrot red
15 (53.6%)
Diamantschwarz Metallic (black)
5 (17.9%)
Alpinweiss II (white)
1 (3.6%)
Lazurblau Metallic (blue)
4 (14.3%)
Sterlingsilber Metallic (silver)
3 (10.7%)
Total Members Voted: 23
Voting closed: August 13, 2015, 04:43:44 PM
Author Topic: shifter prob  (Read 126275 times)
normboudreault
Re: 1991 318iS resto
« Reply #360 on: September 29, 2015, 10:13:36 AM »
How in the world do you sand, prime, sand, prime, sand, spray, and manage to keep the garage so clean and tidy? How do you keep the dust and fumes from getting everywhere?
Great job!
Answer: AIR PRESSURE  ;)
Darky - Thanks amigo.
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #361 on: September 30, 2015, 01:51:40 PM »
Neighbours must love you!
I thought it was a great idea to use my leaf blower to keep the tools and woodworking area clean during a summer project. Didn't know it would coat every car, window and patio on the street with stubborn MDF dust. I hope they won't hold a grudge, it was of Exxon Valdez proportions.  :-\
By the way, great looking body work! I hope to get at mine someday, if I can sort out all the drivetrain issues i've been having since I rolled past 160,000 miles.
« Last Edit: September 30, 2015, 01:55:32 PM by Slowered318 »
normboudreault
« Reply #362 on: October 01, 2015, 07:36:54 AM »
Actually the dust hasnt been that bad... I used as little bondo as possible and the body was more or less in good shape... Still, the interior of the garage will be furiously cleaned while the car is being painted... I am somewhat of a tidy person  ;D
I will update maybe later today..started going to the gym again..havent done that since 2001 but I used to be pretty serious about it..So at 43 I figured I didn't want to age gracefully - good thing Im in good trim to begin with... but Im SORE everyday now although it only hurts when I move something... :-\
Slowered - drivetrain issues? Que pasa?
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #363 on: October 01, 2015, 08:45:07 AM »
You're offering me a free therapy session? great!
Replaced the transmission a few years ago, it's been working great but I suspect one of the bearings is toast, possibly on the input shaft. It's making a lot of noise in neutral when the clutch is engaged.
As for the engine, I tore it down shortly after buying the car (14 years ago). The only major wear I found was the pistons and timing chain components, I replaced those and rebuilt the head. Motor was tight and relatively trouble free up until a few years back. Long story short it's burning a lot of oil again, ticking relentlessly and combustion chambers are filthy.
It's getting too late in the year to wrench on it. Picked up a brand new Tacoma to keep me happily motoring in the meantime. Tossing between the option of A: rebuilding the motor on my own with a lower mileage block (this could take years) or B: Throwing both the motor and transmission in the back of the truck and driving down to Metric Mechanic. or finally C: getting out of the game completely as the car needs body work as well.
keflaman
  • -Receive: 35
« Reply #364 on: October 03, 2015, 09:47:53 AM »
Paint it separately...but, what the hell do I know? I've never painted a whole car before, let alone half a dozen like you. :)
normboudreault
« Reply #365 on: October 03, 2015, 12:48:00 PM »
 ;D ;D ;D
Funny!
Darky
  • -Receive: 23
« Reply #366 on: October 08, 2015, 08:35:24 PM »
Look Norm some rude bugger parked his rust free red 318is right behind you! What a tease.  :P
normboudreault
« Reply #367 on: October 09, 2015, 07:23:49 AM »
I, uh..aaah...mmm...
keflaman
  • -Receive: 35
« Reply #368 on: October 09, 2015, 07:45:25 PM »
Door frames done as well...
Are you using just plain old piss-can primer?
normboudreault
« Reply #369 on: October 10, 2015, 03:52:46 PM »
Yes, I am using "plain old piss can primer".
I am however, applying it with amazing skill.  ;)
Darky
  • -Receive: 23
« Reply #370 on: October 10, 2015, 05:45:54 PM »
Seriously Norm, after all that work you will have to build a stroker even a 86*83.5mm.
My thoughts anyway.
keflaman
  • -Receive: 35
« Reply #371 on: October 11, 2015, 07:44:01 AM »
Oh, no doubt! I was just curious if it's compatible with the gray (grey) primer you are using?
normboudreault
« Reply #372 on: October 11, 2015, 10:34:51 AM »
Yes.. They are both the same brand and basically a step one (high build) and step two (finishing primer). I'm also using a primer/sealer, same brand, to help give it as smooth a finish as I can prior to paint.. I know the guy who will paint the car and he says he will put a final primer on it just prior to paint.. That will basically be just a dusting...
Im final sanding to 800 grit which is overkill but I think this whole project is a bit of overkill so it seems right...  ::)
Darky
  • -Receive: 23
« Reply #373 on: October 15, 2015, 02:00:51 AM »
Nice mate!!
« Reply #374 on: October 16, 2015, 07:11:06 AM »
Nicely done...you're really close to having that rolling around again.
