Author Topic: M42 Turbo Oil Return Line  (Read 11698 times)
E301000
« on: March 04, 2013, 12:22:03 PM »
Hello All
I am planning a top mount turbo project for my E30 M42 318is and would like to know if it is possible to tap into the block to install the turbo return line instead of the oil pan location. Please give me your suggestions on the best location on the block.
You comments are welcomed....Pics too if possible.
Thankd
romkasponka
« Reply #1 on: March 04, 2013, 02:10:28 PM »
I saw some people did it on the oil dip stick. It is not the best place but easy to do.
E30 318is M42
E36 318is M44
E301000
« Reply #2 on: March 06, 2013, 10:49:49 AM »
Thanks, any other suggestion ?????
romkasponka
« Reply #3 on: March 06, 2013, 12:46:53 PM »
Other sugestions are drill the hole in block or sump above oil level and install the fitting for the hose. This way all the things should be nice and compact.
E30 318is M42
E36 318is M44
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #4 on: March 06, 2013, 01:40:05 PM »
Agreed. You can drill and tap above the sump line.
-Nick
91 E30 M42 with VEMS
E301000
« Reply #5 on: March 07, 2013, 07:45:45 AM »
Thanks guys ....
any pics ???
fumstoo
« Reply #6 on: March 07, 2013, 03:39:15 PM »
Heres mine
E301000
« Reply #7 on: March 08, 2013, 07:56:06 AM »
Thanks for the pics ......Anyone else with a picture of the block being tapped for turbo oil return. This should be helpful for all the novices like myself.
Turbo_folke
Re: M42 Turbo Oil Return Line
« Reply #8 on: March 20, 2013, 01:14:10 PM »
really bad picture but it's better than anything
http://www.ladda-upp.se/bilder/pvqpfrpaftsokz/
318 IS turbo
MLM
  • -Receive: 10
    • My M42 ITB Project
« Reply #9 on: March 20, 2013, 03:22:50 PM »
Ive seen the timing case used before.
bar73k
« Reply #10 on: April 19, 2013, 05:23:52 AM »
Here is my oil return line, if you tap into the block then you need to do it when the motor is stripped down
rob_e30
« Reply #11 on: April 26, 2013, 11:58:05 PM »
Here is where we did it...  Don't forget to factor in your motor mount and exhaust locations.
DRTE30
« Reply #12 on: May 04, 2013, 07:57:31 PM »
Is there a reason for installing the return here as opposed to the standard return back into the oil pan? Personal preference? Engine oil starvation? More vacuum or a more direct, vertical alignment?
wazzu70
  • Nasty Nick
  • -Receive: 18
« Reply #13 on: May 05, 2013, 12:02:37 AM »
The oil return should be above the oil line in the pan. If it is not the oil can back up in the return line and burn in the turbo (smoke out the exhaust).
-Nick
rob_e30
« Reply #14 on: May 08, 2013, 07:49:35 AM »
We installed the inlet farther back in the block in order to allow the oil to cool against the pan as it ran down to the sump.  It was also above the sump level.
