Author Topic: Ignition Wires for COP Kit  (Read 4925 times)
vpilarry
« on: February 11, 2013, 08:44:03 PM »
NMNA - http://www.r3vlimited.com/board/showthread.php?t=278534, see the "m52b28 coil harness".
You can use the 4 longest coil harnesses out of this and hide the splices to the OEM harnesses under an M3 firewall cover (if you have one). Here's a pic of mine:
keflaman
  • -Receive: 35
« Reply #1 on: February 12, 2013, 05:15:41 AM »
Damn, we need to get together some day so I can steal some of your ideas for my car. That's a very sharp looking engine compartment!
keflaman
  • -Receive: 35
« Reply #2 on: February 12, 2013, 01:10:09 PM »
I shouldn't be allowed to click on links.
I'll need the wiring diagram and part numbers to install this on my car.:D
vpilarry
« Reply #3 on: February 13, 2013, 07:48:11 AM »
You don't really need a wiring diagram. All the coil wires are green, black and brown/orange as are the wires in the M52 harness.
1) Before you remove the harnesses from the coil pack mark each one so you know which one goes to coil #1, etc.
2) Remove the 4 longest sets from the M52 harness.
3) Install the COP Kit.
4) Install the M52 wires onto your 4 COP coils with the longest at coil #1, etc. Dress them as you please - I used heatshrink tubing.
5) I crimped 1/4" terminals onto the M52 wires (I forget if they're male or female - it'll be obvious).
6) Plug the coil #1 M52 wire into the cars coil #1 wire connector - match the wire colors at each connector (black to black, etc). Repeat for the other coils.
7) Instead of steps 5 and 6 you could just use wire splices but my method allows you easily convert back to the original setup if you ever want/need to.
8) Hide the connections behind the M3 panel. I cut a piece out of the bottom of the panel for the harness to feed through - see my pic above.
keflaman
  • -Receive: 35
« Reply #4 on: February 13, 2013, 04:58:35 PM »
Okay, I gotcha. Thanks for posting.
rob_e30
« Reply #5 on: February 16, 2013, 12:30:23 PM »
I have put together a wiring diagram that shows the correct pins at each end.  We'll be posting that soon, and making it available on our website if there is interest.
rob_e30
« Reply #6 on: February 18, 2013, 04:46:47 PM »
Here is the promised COP Plug Diagram for those of you with the later model M42 or any M44 engines.
keflaman
  • -Receive: 35
« Reply #7 on: February 18, 2013, 07:52:10 PM »
I have a file of PDFs for my car and this one will make a nice little addition to the collection.
Thanks, Rob!
