Author Topic: Anyone have independent foglights?  (Read 6025 times)
Alpine003
« on: November 13, 2006, 01:38:44 PM »
I tried 2 of the methods that were posted without success. I think our '91's have a different wiring scheme. If no one has done it successfully, maybe it's time to break out the multi-meter and have a go at it.
« Reply #1 on: November 13, 2006, 01:45:50 PM »
I have them, they work fine. Don't remember how I did it, but the method came off the internet...  which two methods did you try?
FL318is
fogs
« Reply #2 on: November 13, 2006, 01:49:39 PM »
I think I saw a DIY on E30 or bmwdiy.com.  BUT, the fuse box had different relays.  I recall one was purple so I didn't attempt it.  I would still like to do the conversion if you guys have or will do it.
Alpine003
« Reply #3 on: November 13, 2006, 02:36:49 PM »
Quote from: ak96ss;13694
This was one of them but I forgot the other one off the top of my head.
http://e30.bmwdiy.info/indy-fogs/index.html
Both had you tap into the relays.
« Reply #4 on: November 13, 2006, 03:17:22 PM »
OK, I'll have to look at my car, 'cause that is not how I did it - I have my fogs with the highs as well as without the headlights at all.
I'll let you know, but it will probably be a few days before I get to it.
Alpine003
« Reply #5 on: November 13, 2006, 03:27:23 PM »
Quote from: ak96ss;13698
Thanks. It won't be til the weekend til I can do some diagnostics so if you could let us know by then, you'll have saved me the hassle.
redhead
« Reply #6 on: November 14, 2006, 08:14:26 AM »
Alpine003
« Reply #7 on: November 14, 2006, 11:20:53 AM »
Quote from: redhead;13731
Try this :
http://www.timthurber.com/frontfogs.html
Good luck,
Eugene
Thanks Eugene and have you tried this method yet?
redhead
« Reply #8 on: November 14, 2006, 04:32:56 PM »
Not yet, as soon as I get my lazy ass to do it I will. Tried the other method and it just left my lights on.
Cheers,
E
e9nine
« Reply #9 on: November 14, 2006, 08:52:24 PM »
I have always had the modified relay work for me. It did on 2 of my m42s as well as another guy's m42. Excuse the crappy pic - I just took it and I was in a rush.
  • Take the fog relay out
  • Run a wire from prong # 85 to the tab directly infront of it and bend it down as shown in the pic
  • Test it before you solder the wire (excuse my crappy solder - hey it works!!)
  • Plug it back in - Turn the parking lights on & press the fog light switch.
  • Solder the wire upon verifying it works.
« Reply #10 on: November 14, 2006, 11:48:13 PM »
Quote from: e9nine;13771
I am about 95% sure this is how I did it, and it does work.
Alpine003
« Reply #11 on: November 15, 2006, 12:12:24 PM »
Thanks guys. I will try this. I guess the key is to bend the tab which the other mod writeups I've read don't have you do.
Alpine003
« Reply #12 on: November 20, 2006, 01:12:24 PM »
Thanks guys again. I did this over the weekend and it worked like a charm.
e9nine
« Reply #13 on: November 20, 2006, 11:19:27 PM »
No prob dude. Somone make an article or sticky this. I am too lazy :rolleyes:
DZick
« Reply #14 on: November 25, 2006, 05:36:58 PM »
That is how i did it and it worked
