Author Topic: Has Anyone Installed an Oil Catch Can on PCV Breather Hose?  (Read 13102 times)
« on: April 29, 2011, 09:44:08 PM »
I am going to be overhauling my engine's entire cooling & air/ventilation system in a couple of weeks. Since I am going to all this trouble, I would like to stop all the oil seepage from the crankcase...most of the intake system is coated in oil and it is really annoying. Aside fro the mess, it shortens the life of all the rubber bits.
So, who's found a nice clean way to install an oil catch can in there? I'm looking for simple, effective & compact solutions. Post yours up!
M5wanaB
« Reply #1 on: May 02, 2011, 12:14:19 AM »
I had a pretty nice oil catch setup on my previous 525i with the M50 engine in it that I have been thinking of doing for my M42 as well. what you do is hook up a moisture trap/oil separator for a compressor with two barbed fittings to slip on the breather hose for the in/out. Its only about $10 in parts and an hour of your time.
romkasponka
« Reply #2 on: May 03, 2011, 01:44:42 PM »
romkasponka design studio :D
E30 318is M42
E36 318is M44
rjcaptsean
« Reply #3 on: May 03, 2011, 02:58:27 PM »
I dont think a "hose into an empty pepsi bottle" was the concept he was looking for.  :)
Bl0mgren
« Reply #4 on: May 03, 2011, 05:28:57 PM »
Quote from: rjcaptsean;103541
works great! simple and effective ;)
M5wanaB
« Reply #5 on: May 03, 2011, 05:49:54 PM »
use a compressor air filter, they sell em at harbor freight for $6 then you just use some hose nipples the correct size that screw right into the air filter. $10 bucks and looks tits.
I used this on my Supercharged M50 and it worked great. Nice clear plastic so you can see how much oil it has pulled and has a drain on the bottom so you don't have to remove it to drain it.
« Last Edit: May 03, 2011, 05:52:32 PM by M5wanaB »
romkasponka
« Reply #6 on: May 03, 2011, 07:04:02 PM »
The only problem is that during winter water collected in the bottle can freeze and you can end up with blocked breathing hose :)
P.S. Used for about two years without any problem.
E30 318is M42
E36 318is M44
« Reply #7 on: May 03, 2011, 07:12:29 PM »
Good ideas guys. I hadn't really thought about using HF/McMaster. I found an inexpensive, inconspicuous filter. Small, cheap & discrete.
http://www.mcmaster.com/#catalog/117/953/=c5er6n
PN 41575K58
Now I just need to find a local shop with a good parts cleaner. I am rebuilding all the PCV & coolant stuff on the engine in a couple weeks, and since I'll be adding this filter, I might as well get all the gunk out once & for all!
« Last Edit: May 03, 2011, 07:27:06 PM by bmwman91 »
monty23psk
  • -Receive: 17
« Reply #8 on: May 03, 2011, 08:53:17 PM »
Keep us posted as very interested and didnt have time to do something like this during my rebuild as I needed my car on the road ASAP.
« Reply #9 on: May 04, 2011, 07:44:05 PM »
Will-do. I'll take a couple pics once I get the catch installed (might be a few weeks before I get around to rebuilding the PCV & cooling systems though).
filip
« Reply #10 on: June 17, 2011, 08:55:11 AM »
slamjam73
« Reply #11 on: January 26, 2012, 04:46:58 PM »
bump. ^^^
Has anyone, or know of someone, used/using the original oil separator from the E30 M3?
DiRTY-D
Re: Has Anyone Installed an Oil Catch Can on PCV Breather Hose?
« Reply #12 on: August 19, 2013, 10:07:04 PM »
i just bought an oil catch off ebay last week for $20 i will have to put pics up later since i just put it on 2 days ago
Slowered318
  • -Receive: 9
    • My '91 318is
« Reply #13 on: August 20, 2013, 08:36:20 AM »
I really like the look and design of this one. http://store.42draftdesigns.com/Stealth-Oil-Catch-Can_p_289.html
bme30
« Reply #14 on: August 20, 2013, 10:17:59 AM »
This is mine..
Moroso air/oil separator
