Sorry I haven't updated in a little while, my "real" job and life have been hectic. Work is still going on this, and I am hoping to finish testing all the boot-loader stuff this weekend. From there, I need to work out the tuning section. At this point, I WILL make it possible to use different MAFs. As I get parameters for new sensors, I will be able to release MAF data files that can be imported into the GUI and then loaded onto the converter.
Thereafter, I will finish up the firmware for the converter's controller. THat will probably take a week or two. Luckily, I already have the main portion of the code written. I just need to add in the interface stuff for tuning.
Finally, I will need to actually BUILD this. The hardest part will be sourcing molded cable strain reliefs and finding an appropriate enclosure for this. I have a few leads on companies that do this sort of thing for small-medium volume products. This is all being funded personally, which makes things a little trickier. If anyone knows of a good source of reasonably priced multi-conductor cable, strain reliefs & small water-tight enclosures let me know!
Thanks!
