Some of you know that I have been tinkering around with a MAF conversion for a few years now. Initially I wanted to develop it into a product, but that idea died when it became obvious that a MAF won't really do anything for the M42's power output. Well, I have been expanding some of my converter's functionality & decided to see if the current idea was popular.
At this point it might be a desirable replacement option for 20+ year old AFMs being that they can cost anywhere from $160 to $700 to replace (or $40 at a local wrecker, but you never know what you'll get). This may change, but I am looking at a ~$200US price point for the converter only (subject to change, up or down). The MAF sensor, & hardware to make it fit on the car, are not things I am planning to manufacture or sell at this point in time.
Here are the features I would start out with:
No-nonsense MAF conversion for M42 cars
- Some cutting of factory AFM harness
- Extra connector parts so that stock AFM could be plugged back in with minimal effort
- Overall design such that MAF / AFM could be interchanged in ~5 minutes with no need for tools
- About 20ms latency with filtered output
Selectable output variable
- Puts out either mass flow rate, or volumetric flow (AFM-emulation) rate
- Choice of filtered or unfiltered output (filtered is a good idea unless you know a LOT about the ECU you are working with, and is a must with Motronic)
Tunable output parameters
- With volumetric output (AFM-emulation), choice of stock-style logarithmic output or linear output
- - Tunable logarithmic & linear outputs
- With mass flow rate output, linear output
- - Tunable linear output
PC Graphical Interface
- Used to select output mode and tune output curve parameters
- Can log & plot filtered+unfiltered air flow and intake air temp in real-time
- - Thinking about having analog input for wide band & narrow band O2 sensors - not 100% sure yet
- Used to apply firmware updates (not 100% sure about this yet)
The current sensor can handle flows up to ~810 kg/hr (according to the data sheet), but I think that somewhere in the 500-600 kg/hr range is more reasonable. A stock M42 will generally flow ~350kg/hr at most.
When I say tunable output curves I mean:
- For linear output, Vout = m * FLOW + b with m & b being adjustable
- It's a similar deal for the log output - only 2 parameters to adjust
The purpose of the linear outputs would be to make tuning with things like the WAR chip / TunerPro and running MS easier.
The timeline for this would be a few months. I have a day job & I don't plan on quitting any time soon!
