Author Topic: FEELER: Tunable MAF Conversion Interest?  (Read 21695 times)
turbo 318
little clip
« Reply #15 on: January 28, 2011, 03:03:22 AM »
« Last Edit: February 27, 2011, 01:24:24 AM by turbo 318 »
trackjunkie21
« Reply #16 on: January 28, 2011, 10:59:14 AM »
Holy crap, that is seriously badass.
turbo 318
« Reply #17 on: January 28, 2011, 08:27:03 PM »
« Last Edit: February 27, 2011, 01:30:25 AM by turbo 318 »
« Reply #18 on: January 28, 2011, 11:54:59 PM »
Damn, do you have a turbo AND SC M42? Those are some freaking sweet looking builds!
turbo 318
« Reply #19 on: January 29, 2011, 12:12:11 AM »
« Last Edit: February 27, 2011, 01:30:55 AM by turbo 318 »
Hey-u
« Reply #20 on: January 29, 2011, 12:15:52 AM »
Quote from: turbo 318;100966
no the supercharger is my old motor and the turbo is on my new motor... going to buy a  junker  strip it and put my old set up in it...
Have you considered selling the supercharger?
turbo 318
« Reply #21 on: January 29, 2011, 03:49:02 AM »
soon ill have a dasc for sale in the near future fully rebuilt with powder coat will be asking $2400.
« Last Edit: February 27, 2011, 01:26:57 AM by turbo 318 »
« Reply #22 on: January 29, 2011, 08:51:04 AM »
Quote from: bmwman91;100770
M20 guys claim gains from a MAF, but that is only because the stock AFM was too small to begin with. The power gains from a MAF on the M20 are the same as putting an M30 AFM on. A certain other MAF conversion that will remain nameless claims gains too...but a chip comes as part of the package. The gains come from the chip, and are remarkably similar to the power gains seen when one adds JUST a chip.
I'm really glad to see this happening.  Coming from such a well-regarded member of the board I'm really looking forward to seeing this happen.  I'd suggest that you don't forget the M30 guys (there are a surprising number still out there).
I had a similar idea a long time ago, but I was thinking along the lines of a Megasquirt/Ford Mustang MAF/integrated IACV to eliminate a few of the M42's problems.  Your idea is far more economical and has many more advantages - much cheaper, stock hardware, no cutting the stock harness and it can pass enhanced inspections as it looks relatively stock.
« Last Edit: January 29, 2011, 08:55:20 AM by DesktopDave »
trackjunkie21
« Reply #23 on: January 29, 2011, 09:01:32 AM »
Quote from: turbo 318;100968
:O I'm getting my wallet ready.
« Reply #24 on: January 29, 2011, 06:44:57 PM »
Quote from: DesktopDave;100969
It should be fairly easy to get the M30 AFM working here too.
There is a small amount of cutting required on the stock AFM harness, but you are basically sticking GM Weather-pak connectors on & the kit will include an extra one that you attach to the original AFM connector so it can all be put back together.
« Reply #25 on: January 31, 2011, 10:25:46 AM »
I'm definitely interested. My m42 beater is almost ready and I would to switch over to MAF on that car.
« Reply #26 on: January 31, 2011, 11:24:44 AM »
Quick update...
I am almost done with the toughest part of the project: developing a firmware update system. I want to be able to release firmware updates just in case some sort of unforeseen bug appears, or if I want to add features later / etc. This is the most time consuming part though, because it has to work perfectly. I can't be sending out updates that turn the converter into a brick!
turbo 318
« Reply #27 on: January 31, 2011, 02:36:28 PM »
« Last Edit: February 27, 2011, 01:29:15 AM by turbo 318 »
bmwconnect
« Reply #28 on: January 31, 2011, 04:59:09 PM »
bmwman91 why not go threw the eprom code and adjust the constants for the AFM and scale for the MAF ?
I will gladly help out I just can't be testing such Ideas on customer cars due to time consuming issues, but if someone wants to be a Guinna pig I will help out the best way I can
To me is just sounds better if you stick the MAF chip in the DME and then plug the MAF in and GO!
Kind Regards|
Midnight YouTube Channel
turbo 318
« Reply #29 on: January 31, 2011, 07:46:57 PM »
« Last Edit: February 27, 2011, 01:31:25 AM by turbo 318 »
