Will these fit? What offset should i look for?
Author Topic: Will these fit? What offset should i look for?  (Read 5468 times)
goober
« on: January 03, 2011, 05:54:29 PM »
16x7   4x100 +35 offset and BSM of 5.303
Because I dont know how to insert pictures, they are MSR style 068.
Any help is greatly appreciated
Thank you
« Reply #1 on: January 03, 2011, 08:17:42 PM »
http://www.1010tires.com/wheeloffsetcalculator.asp
Here's a good thread too:
http://www.maxbimmer.com/forums/showthread.php?t=54146
Stock rim (that's what I run) is a 14x6 with an offset of 35mm.  Your wheel will be 10mm closer to the strut (about 3/8"), 16mm farther out.  If I was in your shoes I'd be out there with a ruler to see how much room I had.
They seem a little close for (my) comfort, but a little rubbing isn't the end of the world.  Spacers are pretty cheap (don't forget longer lug bolts too), so even if you make a mistake you're not totally out of luck.
goober
« Reply #2 on: January 03, 2011, 09:30:10 PM »
Nice threads, I have checked out the second one however the first one is new to me.  I'd prefer to have no rubbing whatsoever, however if I were to put say 215/40/16 on them, could I use them on my 318is without causing permanent damage?  If there would be rubbing, should I get 10mm spacers?  Thank you for your help, its really appreciated as I'm new to this.
« Reply #3 on: January 03, 2011, 10:24:42 PM »
depending on the tire size, YES.  I would deff suggest at least a 15mm spacer.  Like Dave said the rim itself will be 10mm closer to the strut and just over 1mm out past the old rim.
goober
« Reply #4 on: January 04, 2011, 08:03:03 AM »
Sorry but what brand or make would recommend?
Thank you
« Reply #5 on: January 04, 2011, 11:26:24 AM »
I would stick with the big names.  Tires are VERY important.
-Falken is prob the best bang for buck.
Good names, in no specific order
-Bridgestone
-Continental
-Goodyear
-Hankook
-Michelin
-Yokohoma
You can go outside these brands but I would not recommend it.
goober
« Reply #6 on: January 04, 2011, 03:13:26 PM »
Ok thanks, I'll probably end up getting yokohamas.  How about for the spacers, I've been looking at eibach, and do they need to have certain specifications I need to know about?
thank you
« Last Edit: January 04, 2011, 06:15:57 PM by goober »
« Reply #7 on: January 04, 2011, 06:43:28 PM »
Just make sure they are 4x100 and are hubcentric to e30's (57.1mm)
goober
« Reply #8 on: January 04, 2011, 08:46:59 PM »
Thank you very much for your help.  Now for a pure aesthetic question...silver gloss?  Or black?
Thanks
Btw, I have an alpine white 91
« Last Edit: January 04, 2011, 10:54:34 PM by goober »
« Reply #9 on: January 05, 2011, 10:27:28 PM »
Personally I would either do a bronze or a gunmetal wheel.  Can depend on the wheel though ;)
goober
« Reply #10 on: January 06, 2011, 07:36:04 PM »
Well thanks for all of your help.  I understand a lot more about e30 fitments and how to fit my car thanks to you guys.  I'm actually considering a different wheel now, same measurements however, a little more of an offset, however I will put 15mm spacers.  They look similar to the BBS LMs.  Black mesh, and polished lip.  I'll be sure to post pictures when I get them on.
Thank you
