Author Topic: M90 Supercharger to M42!  (Read 27483 times)
B318M42W
« on: November 11, 2010, 07:25:55 PM »
well, it's finally done!
M90 supercharger fitted to our little 4 pots.
Goals:
- 7 psi for about 190hp
- keeping it reliable
- buy only what I can't fab.
- keeping the engine clean looking
- keeping it simple
Since I wanted to keep it as simple as possible, I opted for the DASC sytle design
here's the build in pics...
3D manifold
3D intake elbow
fabbed manifold
I didn't want to pay 150$ for a K&N filter with the bracket adapter and wait for the part to arrive in I don't know how long, so I made my own 3" filter bracket for the AFM...
3" aluminum pipe and 1/8" AL plate
Find hole locations and then cut
Fibreglass the peices together through the interior and then once it's dry apply 2 layers on the outside
Then trim and paint!  no picture of part alone...
To keep it simple, I used the power steering pump as the tensioner, but before I dissabled the pump as not to move extra fluid around.
P/S pump apart
Onto the building part!
a common sight to most of you...
I didn't like the idea of a 25lb wight just hanging from the head, so I added an extra steel bracket that bolts right where the alternator bolts on.
Manifold on!
Blower on!
In order to keep it clean looking, and also for space reasons, I tucked all the piping under the manifold and elbow, in the large hole right beside the starter
Rest of the intake on!
For the details
- #40 injectors
- stock internals
- LC-1 WB 02
- bosch bypass valve
- modified rad hose
- 1:1 pulley ratio giving 6 PSI
- estimated 185hp
- no intercooler
- cooler plugs
- 255 lph TRE fuel pump
- Tuned chip by midnight performance (great to work with!:D )
- relocated P/S reservoir
- stock throttle cable and TB
- 3.91 LSD Medium case diff
- 17" rims
was it worth it?    YES! the torque is amasing! a little too much for the stock clutch to handle so it's on the wanted for x-mass list. It's really great to drive around and play with! best of all, it drives really great around town when getting lazy shifting gears. She has a really nice purr at idle however can't hear the charger under load (pulley ratio and loud exaust).
« Last Edit: November 11, 2010, 08:09:12 PM by B318M42W »
M90 Blown M42 :cool:
Romrog318is
« Reply #1 on: November 11, 2010, 07:47:31 PM »
very cool!!
and not to be a dick but those wheels....
not feelin them! lol
no more M42
YetiX
« Reply #2 on: November 11, 2010, 08:07:37 PM »
That is really, really cool. ;)
-Scott-
\'91 318i 5spd
Ryann
« Reply #3 on: November 11, 2010, 08:12:24 PM »
Nice work, man!
cadence
« Reply #4 on: November 12, 2010, 09:43:44 AM »
what car did this supercharger come off of? did you convert it to vbelt?
B318M42W
« Reply #5 on: November 12, 2010, 02:40:39 PM »
thanks for the comments! The charger is off an early 90's thunderbird acording to eaton, but it seems to be almost brand new! It's still in V-belt but i'm considering going to serpentine in the spring
superpotter80
« Reply #6 on: November 12, 2010, 02:46:13 PM »
Quote from: B318M42W;98596
looking good,how does it run.
[SIGPIC]
e30boarder
« Reply #7 on: November 12, 2010, 03:03:43 PM »
you should fab a few more intakes.. im sure someone would be interested in them :)
B318M42W
« Reply #8 on: November 13, 2010, 06:45:22 PM »
It runs great! it runs just like if it had no charger and when you step on the gas, it just goes! lots of instant torque, when you want it.
As for the manifolds, I guess i could fab some base ones, but not 100% done since charger bolt pattern and position differs from model to model.
bmwconnect
« Reply #9 on: November 13, 2010, 07:25:52 PM »
your welcome /\ hehe :P
Midnight YouTube Channel
cadence
« Reply #10 on: November 15, 2010, 11:17:34 AM »
in case anyone was wondering.  it looks like this is an m90 off of a jaguar because of the short snout.
http://www.invasionautoproducts.com/supercharger-jaguar-sc-jgnbd-77000-ba.html
B318M42W
« Reply #11 on: November 15, 2010, 12:43:29 PM »
True, but i sent an email to eaton with serial # and this is what they answered
Dear _____,
This unit is from an older Ford M90 from the 3.8L Super Coupe.
Regards,
Barney Gwozdz
Customer Support
Technical Specialist
Phone# (248)226-6234
Fax#     (248)226-6740
Pretty sure fords are easier to find than Jags :p
« Last Edit: November 15, 2010, 12:46:02 PM by B318M42W »
trackjunkie21
« Reply #12 on: November 16, 2010, 07:46:51 PM »
So you're on the stock motronic? All you have is a wideband 02 sensor and a chip? Seems like a better option than a turbo:p, you can find thunderbirds in the junkyard all day.
B318M42W
« Reply #13 on: November 16, 2010, 09:32:15 PM »
Yeah stock ECU with a tuned chip, WB O2 and #40 injectors.
« Last Edit: November 16, 2010, 10:25:04 PM by B318M42W »
TooTall90
« Reply #14 on: November 17, 2010, 09:42:54 PM »
very nice, it would be cool if you could make some more intakes.
videos?
