Author Topic: e36 318is turbo/itbs pics  (Read 19064 times)
superpotter80
« on: November 06, 2010, 10:11:49 AM »
some more pics of my engine
« Last Edit: February 11, 2011, 03:04:58 PM by superpotter80 »
[SIGPIC]
« Reply #1 on: November 06, 2010, 10:15:49 AM »
That's purty.  How's it run?
Is that an OEM BMW e36 radiator fan?  Does every M42 e36 have one?  I was looking to get something like that for my e30.
superpotter80
« Reply #2 on: November 06, 2010, 10:18:39 AM »
Quote from: DesktopDave;98393
yea it is,you need a late e36 318 for the electric fan,runs amazing for being on standerd ecu
[SIGPIC]
« Reply #3 on: November 06, 2010, 12:45:05 PM »
You chipped a Motronic DME with the turbo?  Or did you do a RRFPR?
How's the stock clutch holding up?
I'll look for the later model; most of the early ones I've seen still have the clutch fan.
bmwconnect
« Reply #4 on: November 06, 2010, 02:36:21 PM »
nice setup!!
Midnight YouTube Channel
superpotter80
« Reply #5 on: November 06, 2010, 03:56:08 PM »
Quote from: DesktopDave;98397
yea it has a chip,and a rrfpr,bigger injectors,the clutch couldnt cope so i fitted a spec stage 3 paddle clutch
[SIGPIC]
superpotter80
« Reply #6 on: November 06, 2010, 03:57:05 PM »
Quote from: bmwconnect;98398
nice setup!!
thankyou
[SIGPIC]
PFCRayB
« Reply #7 on: November 08, 2010, 03:54:10 PM »
what intake mani is that?
bmwconnect
« Reply #8 on: November 08, 2010, 04:05:59 PM »
Quote from: superpotter80;98399
Why are running a RRFPR if you are chipped and have bigger injectors?
superpotter80
« Reply #9 on: November 08, 2010, 04:32:22 PM »
Quote from: PFCRayB;98479
its custom made
[SIGPIC]
superpotter80
« Reply #10 on: November 08, 2010, 04:39:04 PM »
Quote from: bmwconnect;98481
i dont thick the injectors were big enough so i see alot of you use rrfpr so i got one  and it works perfect,im not changing to standalone just yet as this all works so well even cold start
[SIGPIC]
deekay
« Reply #11 on: November 09, 2010, 06:25:58 PM »
Quote from: superpotter80;98484
hmm. people tried to talk me out of this (i'm ITBd also), but seeing it done...
edit: nevermind i see it now.
« Last Edit: November 09, 2010, 06:33:33 PM by deekay »
M42_Jester
« Reply #12 on: November 10, 2010, 12:27:59 AM »
are they the ITBs from an S50B32?? if so, where can i get my hands on a set of them, and how did u fabricate them to make them fit?
Jester
superpotter80
« Reply #13 on: November 10, 2010, 09:06:27 AM »
Quote from: deekay;98530
what itbs you got and i take it no turbo yet
[SIGPIC]
superpotter80
« Reply #14 on: November 10, 2010, 09:21:36 AM »
Quote from: M42_Jester;98533
Jester
yes they are s50b32 i had them from a previous car but you can get them from ebay,they wernt that hard to fabricate,just take out the centre 2 itbs cut the linkages down,machine the edges and make some brackets to bolt to head,i turned my fuel rail around and adjusted the fuel in/out lines.you also need to cut the air rail so you can use the sevo/idle valve and make some brackets to hold it all down,it sound alot but once you buy a set you will see it not to hard at all, will try get some pics.
[SIGPIC]
