Author Topic: e36 318is turbo/itbs pics  (Read 19071 times)
M42_Jester
« Reply #15 on: November 10, 2010, 07:12:01 PM »
Quote from: superpotter80;98537
yes they are s50b32 i had them from a previous car but you can get them from ebay,they wernt that hard to fabricate,just take out the centre 2 itbs cut the linkages down,machine the edges and make some brackets to bolt to head,i turned my fuel rail around and adjusted the fuel in/out lines.you also need to cut the air rail so you can use the sevo/idle valve and make some brackets to hold it all down,it sound alot but once you buy a set you will see it not to hard at all, will try get some pics.
good to hear. can't wait to see how they all came together
Jester
amend: also forgive me for asking, but if not sticking a turbo on the engine, is there much point for ITBs? wats their significance?
« Last Edit: November 10, 2010, 07:56:41 PM by M42_Jester »
deekay
« Reply #16 on: November 10, 2010, 07:58:17 PM »
Quote from: superpotter80;98536
what itbs you got and i take it no turbo yet
dbilas. i have turbo + manifold + intercooler/piping, generally about 80% of what i need, but since even the ITBs are illegal here in the people's republic of california (that goes for turbo too), i'm debating just swapping to M50 instead... not sure.
superpotter80
« Reply #17 on: November 11, 2010, 01:07:45 PM »
Quote from: M42_Jester;98552
Jester
they do give very good throttle responce and with cams would give you a good gain in bhp,but becarefull when getting a airbox made as you need to make sure that the intake runners are not short because you will not gain at all.
[SIGPIC]
superpotter80
« Reply #18 on: November 11, 2010, 01:11:46 PM »
Quote from: deekay;98553
is that coz of emissions?that is a shame as you have all the bits,but those m50s are good engines and 200bhp out the box.
[SIGPIC]
deekay
« Reply #19 on: November 11, 2010, 01:16:53 PM »
Quote from: superpotter80;98573
yes. there are two parts to the smog test here in california- the "sniffer" part which actually measures how clean you are, and the "visual" part where they look to see if any modifications you've done are on the state-approved list. my car passes the sniff test fine (way under limits, actually), but i had to try 4 different shops before i found someone who was willing to ignore the ITBs.
superpotter80
« Reply #20 on: November 11, 2010, 01:28:28 PM »
Quote from: deekay;98574
if you was to turbo your car i take it you would have to have a different  management to run it lean to pass the sniffer,worth asking the shop if he would ignore the turbo aswell.
[SIGPIC]
trackjunkie21
« Reply #21 on: December 04, 2010, 08:03:59 AM »
How much boost you pushing?
trackjunkie21
« Reply #22 on: December 04, 2010, 08:04:42 AM »
Quote from: bmwconnect;98481
Why are running a RRFPR if you are chipped and have bigger injectors?
I thought you need to run an rrfpr if you don't have standalone?
superpotter80
« Reply #23 on: December 05, 2010, 05:31:01 PM »
Quote from: trackjunkie21;99275
runs 10psi with no problem,i dont have standalone just a chip,i needed bigger injectors but had a rising rate regulator from a previous project so i went with it and its been fine with it.
[SIGPIC]
chips
    • http://www.drakedesign.co.uk
« Reply #24 on: December 10, 2010, 03:56:59 PM »
What turbo is that you are using? Also do you have any idea how much power its putting out?
I'd love to see a video of this thing running.
superpotter80
« Reply #25 on: December 10, 2010, 04:21:23 PM »
im using a subaru wrx turbo(td05h) i dont know the power yet but at a guess id say 250+,there are a couple of vids on youtube type in superpotter80
[SIGPIC]
superpotter80
« Reply #26 on: December 10, 2010, 04:29:58 PM »
Quote from: chips;99498
forgot to say its in this months performance bmw mag
[SIGPIC]
nuvolarossa
« Reply #27 on: December 12, 2010, 03:24:16 PM »
Quote from: superpotter80;99500
they gave you a pdf copy of the article? (usually they do, IIRC)
I don't read PBMW but would be nice to read this article :)
you have a performance shop, right? (I read somewhere on internet ;)), I saw E30 S54, nice!
superpotter80
« Reply #28 on: December 13, 2010, 04:30:02 PM »
yea there are three of us that work at munich motors,we built two e30 s54 cars and my one,all three are our own project cars and all three pbmw featured witch is nice,got lots of pics of the two e30 if anybody wants to see them.
[SIGPIC]
Bl0mgren
« Reply #29 on: December 14, 2010, 12:24:43 PM »
post the pics! :)
