Author Topic: Break Pad Wear Sensor Install  (Read 2377 times)
DesertEagle
« on: April 07, 2010, 07:41:56 PM »
Hey All,
Has anyone ever had difficulty installing the rear brake sensor.  I'm talking about just pushing the sensor into the pad cutout.  I cracked one sensor.  The second one sticks when the springs/clasps are fully depressed.  The pads are Textar and the car is a 1991 318is.  Is there something I'm missing or is there a trick to it?
Sincerely,
Churning in my own anger...
1991 E30 M42
« Reply #1 on: April 07, 2010, 09:07:26 PM »
I removed the entire pad wear harness and took the light out of the cluster, problem solved
DesertEagle
« Reply #2 on: April 09, 2010, 08:54:10 PM »
you're not too fond of the stock setup, huh?
1991 E30 M42
« Reply #3 on: April 10, 2010, 01:07:12 AM »
i dont like anything stock
ecalder
    • http://www.lanovatile.com
« Reply #4 on: April 10, 2010, 09:17:29 PM »
I had the opposite problem, on my hawk hps pads the sensor won't clip in tightly, it's loose and just falls out! Should I glue it?
1991 318i 5 Speed
2004 X3 2.5 6 Speed
2011 1M June 17 Euro Delivery!
