Author Topic: lowering 318ic  (Read 2536 times)
tdoyle
lowering 318ic
« on: October 30, 2009, 04:54:39 PM »
Hi, I a new guy..
Has anyone lowered a 318ic? I am having a hard time finding springs. I just want to stiffen it up a bit, not slam it. 1-1.25 inch drop would be fine.:D
tony92ic
lowering 318ic
« Reply #1 on: November 08, 2009, 06:32:11 PM »
E30 M3 springs, no spring pads. (but cut something thin for a liner to prevent vibration).
Firmer, but not too stiff for the loose cabrio chassis. Lower, but not too low.
This is my set up with Bilstein sports and I love it.
Tony
92 e30 318ic - Why I am here
72 2002tii - Much modified
91 M42 - Am I a hoarder?
AcSchnitzer318is
lowering 318ic
« Reply #2 on: November 09, 2009, 08:59:10 AM »
Quote from: tony92ic;81107
E30 M3 springs, no spring pads. (but cut something thin for a liner to prevent vibration)/QUOTE]
Sorry to threadjack, but what did you use as a liner?  Been wanting to do this and haven't been able to think of a suitable material for liner to prevent metal on metal vibing and causing rust.  I want a little more drop in the front of mine running h&r's and billy sports.
tony92ic
lowering 318ic
« Reply #3 on: November 09, 2009, 09:34:52 PM »
On the fronts I used a water softner salt bag. The Cargill stuff is in a really thick heavy duty plastic.  The rear bottom I wanted to keep the bump stop and you need it to center the spring so I just trimmed it down so it just tucked under the spring and provided a cushion without lifting it up. I can't remember what I did for the top rear. Softner bag I'd guess.
Tony
deekay
lowering 318ic
« Reply #4 on: November 09, 2009, 10:46:24 PM »
tunershop has weitecs for a 318ic.
http://www.tunershop.com/Suspensions/Springs/TS_Springs_%28BMW_3er_Cabriolet%29_x200_230x_p27009_h4_m450.html
i actually have a set of these (i ended up using something else after going w/ a 5-lug swap), if you want 'em.
